Yard Sprayer Maybe?
15 replies to this topic
#1 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted May 18, 2015 - 11:18 AM
A while back I was given this 15? gallon tank and I have been trying to decide what to do with it. Yesterday, I bent some 1.25" X 1/4" strap to fit around it.
I have this 12V pump. Not sure what pressure it may have as the numbers are illegible. Looks like it is 10.6 gals/min.
Might make a decent small sprayer for a wand of a pump up tank. Laying the tank on it's side, I may only get ~12 gallons in it unless I put a 90° fitting in the fill hole. Probably have to get a vent in there somewhere so it can breathe.
What do you folks think about it?
  • Alc, boyscout862 and Sawdust have said thanks
#2 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,433 posts
Posted May 18, 2015 - 11:41 AM
Do you need a yard sprayer? I have one that I've never used. Good Luck, Rick
  • KennyP and Bill 76 have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,375 Thanks
  • 10,145 posts
Posted May 18, 2015 - 11:50 AM
If I have to keep moving my yard sprayer around in the shed 10 months of the year to get to what I need, someone else should too.
Build away, Kenny!
  • KennyP, boyscout862, Sawdust and 1 other said thanks
#4 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted May 18, 2015 - 02:28 PM
So far just a passing thought. I do have some trees we planted this Spring that may need watering in the ';back 40'. so I could just use it to transport water to them. I haven't a clue what I'd use it for as a sprayer. Unless I can get liquid fertilizer! And the grass is doing well right now!
#5 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted May 18, 2015 - 02:55 PM
I got this stuff from a friend once and put it in my wagon. Worked good for watering the potatoes. My pump looks the same as yours. All dismantled now, have not used it in a few years.   Noel
#6 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,433 posts
Posted May 18, 2015 - 05:01 PM
I have barrels and a 275 gallon tank to catch rain water. I pick the barrels up with my bucket loader and use a garden hose to water the garden. No pump just gravity to push the water. Everything is empty right now because we haven't had rain.  Good Luck, Rick
#7 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted May 18, 2015 - 07:35 PM
I think it will make a fine lawn/garden sprayer!
#8 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted May 18, 2015 - 07:41 PM
Kenny, that is exactly the chemical barrel I put on my sprayer when my tank cracked.  I have at least a dozen more of them.  Milk parlor chemicals came in mine.  And Kenny, put a street L into the large bung hole, and use the original barrel cap, as it'll screw right into the L.  Then I simply drilled a tiny hole in the cap for air bleed.  The street L makes for an easy fill point.
  • KennyP and Sawdust have said thanks
#9 olcowhand ONLINE
  • 42,899 Thanks
  • 31,942 posts
Posted May 18, 2015 - 07:43 PM
I use my sprayer a LOT late spring & early summer.  Spray around the barn edges & such to cut down on weed eating, then I spray a few barrels of 2-4-D to get thistles.  I gotta get mine fired up tomorrow.
#10 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,549 posts
Posted May 18, 2015 - 09:24 PM
I like the idea too, been thinking about one myself as soon as we get done moving....maybe a winter project for next year's garden. I'll be watching Kenny
#11 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted May 19, 2015 - 05:30 AM
Trying to decide if I want to make an axle to go under it or just set it in a trailer.
  • Sawdust said thank you
#12 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,549 posts
Posted May 19, 2015 - 08:14 AM
My plan was to fab a small frame with axle using a couple of wheel barrow wheels & tires. When empty or not in use just tilt back on its end to store out of the way. I thought about the trailer idea but the need to move it around & rig it up everytime to use changed my mind....I believe :)
Edited by Sawdust, May 19, 2015 - 08:16 AM.
#13 KennyP ONLINE
  • 40,984 Thanks
  • 47,152 posts
Posted May 19, 2015 - 08:33 AM
Thanks for all the suggestions folks! I'm digesting this all and will do something here before long. Continue with the ideas, as there may be something I might be missing.
#14 bbuckler ONLINE
bbuckler
  • 3,764 Thanks
  • 3,271 posts
Posted May 19, 2015 - 09:40 AM
I need to do this for my watermelon patch I don't have enough water hose to water it.
Edited by bbuckler, May 19, 2015 - 09:40 AM.
  • KennyP, Sawdust and propane1 have said thanks
#15 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Posted May 19, 2015 - 05:07 PM
I have a barrel like that and am waiting to find the rest of the things needed to do a build. I was thinking of putting it on the 3 point. It is still in the planning stages yet.
