Replacing the 800's axle seal and trying to get it running
35 replies to this topic
#31 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted March 31, 2011 - 05:26 PM
Got the engine in today. Not fully bolted down but I hope to see if she will run by the weekend :bounce:
#32 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted April 01, 2011 - 04:03 AM
I assume they were the correct ones as he probably gave you NOS seals.
Dont really know why it leaks even worse......
Guess you can always replace them again LOL
i dont think they were, because he ordered them and had them made
#33 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted April 01, 2011 - 09:02 AM
thats the way i did it and it leaks worse than it did before i replaced it....
When replacing the large seal, it is important to de-burr the leading edges of the hub before sliding it back into the seal.
Often, the end of the hub would develop a sharp edge or burr that would cut the new seal, if you did not de-burr.
The two square tangs that protude on the end of the hub, also need to be de-burred.
If the seal is not installed squarely into the housing, it will distort and leak.
If the hub is worn where the lip of the seal rides, leakage will continue.
If the bushing that the hub rides in is worn, the seal will leak.
  • Bolens 1000, Nascar3244888, awol and 1 other said thanks
#34 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted April 02, 2011 - 07:29 AM
by de-burr....you mean file them down a bit? seen you were in jersey...care to come over here to PA and give me a hand?????:worshippy1:
#35 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 02, 2011 - 07:46 AM
What I did on mine was just take some fine grit sand paper and smooth out the rough edges
  • rumbleseat said thank you
#36 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 5122 Thanks
  • 2911 posts
Posted April 02, 2011 - 08:12 AM
Yes, you can use a file, a sharpning stone, or sandpaper, as Brian said. ...........You don't need to remove a lot of material, you just want to slightly chamfer any sharp edges.
