Rear Hitch Education Please?
category 0 3 point sleeve hitch
8 replies to this topic
#1 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted May 17, 2015 - 02:04 PM
I grew up with farm tractors and have a lot to learn about GT's.  I want to be able to use attachments on the back of a QT or Large Frame Bolens.  Hitches for these seem to fall into 2 types-- 3 point (cat. 0) and sleeve hitch.  I don't understand the difference.  Anyone willing to explain?
Thanks, Paul.
  • chieffan said thank you
#2 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted May 17, 2015 - 02:57 PM
Since you grew up on a farm I'm sure that you are familiar with the 3-pt hitch.
The sleeve hitch could more properly be called a 1-pt hitch.  Sleeve hitch implements are connected to the hitch with just one pin.
There is a sleeve hitch for the tube frames, but Bolens did not have a 3-pt for them.
Here's a pic of my Ohio Steel sleeve hitch, another pic with a Hang-H-Haul carrier mounted on it, and a pic of a cultivator so you can see the implement side better.
The large frames have a CAT 0 3-pt hitch available, but no sleeve hitch.  However you can use sleeve hitch attachments with the 3-PT if you have an A-Frame with the sleeve hitch adapter on it.
Here's a pic of an A-Frame adapter on my HDT1000.
Bolens had 2 different 3-Pt hitchs for the large frames.  One for the 1250-1886 tractors, and one for the HT series tractors.  They also had 3-pt hitches for some of the later series like the Duratracs.
  • tinbender7, boyscout862, sodisr and 3 others have said thanks
#3 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted May 17, 2015 - 03:07 PM
So I don't need to look at sleeve hitches as I don't have a tractor that uses one.  Can focus on 3 pt's and an A-frame.  Excellent.  Thanks!!
  • tinbender7, boyscout862 and chieffan have said thanks
#4 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted May 17, 2015 - 03:15 PM
Yes, for the HT23 you would want to look for the #18086 hitch.
For the QT you want the #19200 hitch.  I'm thinking that this one might be hard to find.
  • tinbender7, chieffan and Paulgo have said thanks
#5 boyscout862 OFFLINE
  • 15273 Thanks
  • 10026 posts
Posted May 17, 2015 - 03:17 PM
Nice explanation. Good Luck, Rick
  • OldBuzzard, sodisr, chieffan and 1 other said thanks
#6 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted May 18, 2015 - 07:58 AM
What exactly is the #19200 hitch? I take it that's a sleeve hitch right?
#7 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted May 18, 2015 - 08:09 AM
The #19200 is a 3-PT hitch for the QS16, QT16 and QT17.
Looking at the attachment interchange, it does not list a sleeve hitch for those tractors.
Edited by OldBuzzard, May 18, 2015 - 08:10 AM.
  • Paulgo said thank you
#8 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted May 18, 2015 - 08:10 AM
Cool, I had no idea the QT's had a 3 PT.
#9 rabass41 OFFLINE
rabass41
  • 7 Thanks
  • 9 posts
Posted January 22, 2017 - 09:04 PM
Is anyone in need of a Bolens Q series 3 point hitch (19200)  ?? I have one with rockshaft that I don't need and I know its a hard to find item, if anyone is interested let me know
  • Bolans Boy said thank you
Also tagged with one or more of these keywords: category 0 3 point, sleeve hitch
