ih cub 125 hydro starter generator issues
10 replies to this topic
#1 cub_125 OFFLINE
cub_125
  • 6 Thanks
  • 12 posts
Posted May 16, 2015 - 07:52 PM
I recently picked up an early 70's IH cub 125 hydro in great shape. After running it a few hours the starter stays on After the tractor is started and broke the belt. Can anyone tell me what's causing this? I am hoping not to have to by a New starter/generator.
  • laurarg3 said thank you
#2 cub_125 OFFLINE
cub_125
  • 6 Thanks
  • 12 posts
Posted May 16, 2015 - 09:01 PM
Sorry about the year I looked it up its a 1968 model.
#3 Jlaws OFFLINE
Jlaws
  • 554 Thanks
  • 368 posts
Posted May 16, 2015 - 10:33 PM
It might be the voltage regulator . I have seen that if the contacts stick closed in the regulator it will crank the engine over . That would be the first thing I'd check .
#4 cub_125 OFFLINE
cub_125
  • 6 Thanks
  • 12 posts
Posted May 16, 2015 - 10:38 PM
It doesn't do it all the time if the switch is in the On position only when you crank it. I don't know if that helps tell what it is.
#5 chieffan ONLINE
  • 10,122 Thanks
  • 6,626 posts
Posted May 17, 2015 - 02:01 AM
It could be the ignition switch is bad and sticking in the start position.  It could be the starter relay sticking closed.  Or like Jlaws said it could be the voltage regulator.
#6 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted May 17, 2015 - 05:15 AM
Here's a S/G Repair Manual. Thought I had uploaded a wiring diagram for these. I do some snooping for that.
Found a wiring diagram:
Edited by KennyP, May 17, 2015 - 05:19 AM.
#7 cub_125 OFFLINE
cub_125
  • 6 Thanks
  • 12 posts
Posted May 17, 2015 - 07:57 AM
Thanks for the input guys it is all helpful especially the diagram.
#8 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted May 17, 2015 - 08:32 AM
Hope this helps you get it figured out. If it is the regulator, there are a lot of different types, so make sure they will be a match for yours.
#9 cub_125 OFFLINE
cub_125
  • 6 Thanks
  • 12 posts
Posted May 17, 2015 - 02:01 PM
Jlaw was right some contact cleaner in there and it seems ok. Hopefully get me through the year and hopefully this winter I will put in new points condenser regulator and all that stuff. Tractor is in great shape runs good not a bad deal for cutting down a tree for someone.
#10 cub_125 OFFLINE
cub_125
  • 6 Thanks
  • 12 posts
Posted May 17, 2015 - 10:51 PM
Can anyone tell me how much and were I can get a regulator?
#11 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted May 18, 2015 - 05:20 AM
Hopefully, one of the sponsors will have access to those.
