need help with final details
10 replies to this topic
#1 curts garage OFFLINE
curts garage
  • 40 Thanks
  • 70 posts
Posted May 16, 2015 - 01:12 PM
working on my David Bradley last night and this morning to get it going in the garden,  I need help with throttle and choke linkages, I know choke is just a short rod but don't know where or how to mount it and don't know where to hook up or mount throttle cable.  Tractor has been pieced together from several tractors of mine,  Trying to keep it as original as possible, I know I have a Clinton tank but it had the prettiest paint.  I have a very nice hood, just took it off last night.
Also which way should I put the engine pully on? I've seen them on both ways
I would like to get that adjustable foot into the garden to start hilling up the potatoes!
Edited by curts garage, May 16, 2015 - 01:14 PM.
  • wvbuzzmaster, boyscout862, Nato77 and 1 other said thanks
#2 boyscout862 ONLINE
  • 15185 Thanks
  • 9997 posts
Posted May 16, 2015 - 01:25 PM
Check in the Manuals Section. Good Luck, Rick
#3 Alc ONLINE
  • 9081 Thanks
  • 8325 posts
Posted May 16, 2015 - 05:13 PM
I can't find any pictures of mine so tomorrow I'll get it out of the garage for some close ups for you
  • curts garage said thank you
#4 wvbuzzmaster OFFLINE
  • 4726 Thanks
  • 7423 posts
Posted May 16, 2015 - 05:18 PM
The pulley can be mounted either way. It is a function of speed. 2.1 mph on small side of the pulley, 2.4 mph on the big side of the pulley.
  • Alc and curts garage have said thanks
#5 DougT OFFLINE
DougT
    Dog Approved
  • 8369 Thanks
  • 5751 posts
Posted May 16, 2015 - 06:00 PM
When I saw the topic, I thought you were planning your demise. Glad you're OK.  Good Luck with the DB!!
  • curts garage, Lauber1 and Rock farmer have said thanks
#6 curts garage OFFLINE
curts garage
  • 40 Thanks
  • 70 posts
Posted May 16, 2015 - 07:07 PM
Thanks for the support doug!
I had done some research and learned about the speeds of the pully,  other thing I learned was making the tractor speed slower will speed up the attachments, Thats my plan,  only attachment I plan to use on it is the cord wood saw!
I found a good throttle cable long enough, I have an Idea how it hooks up but not 100 percent certain.
Still lost on choke setup.....
Also need to narrow wheel track up, hopefully tomorrow.
  • DougT and Alc have said thanks
#7 curts garage OFFLINE
curts garage
  • 40 Thanks
  • 70 posts
Posted May 17, 2015 - 10:51 AM
thought i'd get a couple more pics.
I'm guessing that the cable hooks into the left hole and the cable clamps into the notch on the right with a screw and washer.... any thoughts?  picture is flipped to the left for some reason
still curious about the choke linkage........
Edited by curts garage, May 17, 2015 - 10:59 AM.
#8 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted May 17, 2015 - 12:03 PM
Is that a N or an 8? Looks like the air shroud is off a 8 or 6S.
The only way I can see to help you figure out where everything goes is to tell you buy another one that's all complete. lol
#9 Alc ONLINE
  • 9081 Thanks
  • 8325 posts
Posted May 17, 2015 - 12:18 PM
Here's some pictures that I thought might help , let me know if you need other shots . I dont know if and what might have been changed though the years . I only have had it about 3 years and this is how I got it , Al
Edited by Alc, May 17, 2015 - 02:57 PM.
  • curts garage and Lauber1 have said thanks
#10 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted May 17, 2015 - 03:15 PM
looks like you only have about half of the choke pull rod, it should look like the one in the last posted pictures and go thru the bracket on the side. Depending on the tractor model the throttle cable come up from the bottom of the motor mount, from a hole in the handles and hooks up to the linkage slide. the coiled part of the cable would go in that groove with a tiny screw and washer pinching it to the block.
#11 curts garage OFFLINE
curts garage
  • 40 Thanks
  • 70 posts
Posted May 17, 2015 - 10:53 PM
well I think I got it figured out, will try to work on it tomorrow, was busy picking up the yard today and chasing kids.  Thanks for all the input guys.
