New tires and exhaust
2 replies to this topic
#1 Jake OFFLINE
Jake
  • 252 Thanks
  • 142 posts
Posted May 16, 2015 - 12:54 PM
With the 16 hp Kohler in and working I made a new exhaust and put a new set of tru power tires it's coming. Has anyone put a 3 point on a HD12? I like to make one I made one for my case and like it a lot have a good day Jake
  • KennyP, sacsr and tinbender7 have said thanks
#2 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted May 17, 2015 - 08:12 PM
Jake I just have the sleeve hitch set up on mine, so no help.
The HD is looking good. Glad to see you got it up and running.
  • Jake said thank you
#3 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted May 18, 2015 - 08:47 AM
I've never seen a three point on the HD-12, but like you I want to build one.
I was thinking of using the same design as the JBI, it looks like it uses the same cyl as the HD-12 only mounted in the center of the tractor. So it might be possible for you to center it and build the same linkage and have something that looks Bush Hog. I would need to leave my cyl where it is though as the battery needs to go under the seat. Maybe if Olcowhand gets some time he could post up a few measurements and pictures of his JBI cat0.
