DB walk behind. Any ideas of year and model?
17 replies to this topic
#1 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 16, 2015 - 06:32 AM
Hello All,
Here's the proverbial barn find for you. I was told by the original owners daughter that she remembers her dad having it forever but never seeing him use it. I got it home and would you believe everything is free on it? It doesn't have spark but I didn't look into anything yet. Any ideas of what I have here? I will post pictures. The tag is present but not clear enough to make out.
Please let me know.
Thanks
Mike
  • Gtractor said thank you
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 16, 2015 - 07:39 AM
What model is that Continental. That will narrow it down a lot.
#3 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 16, 2015 - 09:50 AM
Don't know. Where would I look
#4 curts garage OFFLINE
curts garage
  • 40 Thanks
  • 70 posts
Posted May 16, 2015 - 12:27 PM
it will be AU8 or AU85 stamped on the engine tag
#5 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 16, 2015 - 01:03 PM
Found it
AU8
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 16, 2015 - 05:07 PM
You have 917.57561 Super Power made from 1951 to 1953.
  • trowel said thank you
#7 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted May 16, 2015 - 05:24 PM
I got one last year too without spark ,turned out the points must have had an oily film on them ,after filing they didn't have conductivity across until I cleaned them with Brake Clean. I just used mine in the garden this week ,started on the first pull . Good engines have fun and post some pictures of the adjustable foot in use
#8 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 16, 2015 - 05:54 PM
Good deal thanks for the info. Where would the points be located on this engine
  • wvbuzzmaster said thank you
#9 Alc ONLINE
  • 6,742 Thanks
  • 7,396 posts
Posted May 16, 2015 - 09:25 PM
The points are under the black cover in the picture you posted . Best to down load the engine manual,the governor needs to be loosened to get the cover off if I remember right .
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 17, 2015 - 05:52 AM
1953 to 1954. The 51 had the Briggs model 6.
#11 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 17, 2015 - 09:27 AM
The 917.57560 was the Briggs 6 Super power and ran the same 1951-1953 range...
#12 case442 OFFLINE
case442
  • 693 Thanks
  • 423 posts
Posted May 17, 2015 - 10:10 AM
Great thank you. I'll look into the manual.
Mike
#13 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted May 17, 2015 - 10:22 AM
http://gardentractor...cooled-engines/
This is the maintenance and operating manual
#14 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted May 17, 2015 - 03:20 PM
560 used a briggs model 8, that's were the super power part came in. Model 6 is only 2hp , model 8 is 2.5.
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 17, 2015 - 08:27 PM
Model 6 or 8 wasn't the point I was making, so did not notice the error that was created. Thanks for the correction.
  • Lauber1 said thank you
