To stack or not to stack
33 replies to this topic
#16 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted May 16, 2015 - 09:46 AM
I kinda like the looks of some stacks...  BUT as stated,, just another thing to look out for when mowing near trees  and things... I took mine off my 1556 bolens..  The support was weak and vibrated some... went to original....
  • rustyoldjunk and holdenboy1960 have said thanks
#17 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted May 16, 2015 - 03:33 PM
I prefer Horizontal exhaust exiting forward but I like the look of some stacks.
It's your tractor, if you want a stack then put it on. :thumbs:
  • wvbuzzmaster and holdenboy1960 have said thanks
#18 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 17, 2015 - 10:18 AM
I really have two goals. I hate the pepper pot mufflers because they are loud and ugly. OEM used them so it commits you to using them....
From what I have understood the only way to get quieter Kohlers is to get a muffler with more volume. There are two kohler mufflers better than the pepper pot mufflers (that hook onto Kohlers) and that is the Gravely, and the Cub Cadet mufflers. The gravely one is stubby enough to point forward, but the Cub Cadet one should be quiter yet, but only one way to point it.. Up..
I like stacks and I would not leave it open like that, I would add a 1.5" exhaust turndown (point it left side) since flapper on a one cyl is going to be annoying at lower rpm...
Anyone have any thoughts to add?
#19 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 17, 2015 - 12:47 PM
I gotta admit, Casey, when I read the subject line to this thread, I fully expected that you were considering stacking tractors to make room for more.
I think stacks are kind of cool myself but, after having one, I think I've injested enough exhaust to think differently.  When Iw as messing more with this stuff I got into taking those Cub Cadet mufflers and mounting them low, horizontal and pointing forward.  No fumes and the noise isn't too bad either.  Also, when I did have a stack, every time I mowed under a tree, sure enough a branch would catch and turn the stack right down enough to blow in my face.  They do look cool though.
  • MH81, wvbuzzmaster and holdenboy1960 have said thanks
#20 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 17, 2015 - 01:40 PM
All good points. Most of these are for show and play. These tractors don't see regular use so doubt it will get snagged on too much. If I aim the outlet I don't think I would invest as much fumes as the pepper pot muffler... But I dunno.
#21 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted May 18, 2015 - 08:21 AM
If you like it go for it! I like them when done right, your Springfield looks good with it.
#22 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 18, 2015 - 10:35 AM
Not on a Gt. The fumes, can not get under anything, noise .I spend too many hours on a gt and the noise adds to fatigue.
I say that after mowing 8 acres on my FORD 1500 THIS WEEKEND WITH A STACK.
#23 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted May 19, 2015 - 05:48 PM
The more you hang out or up there the greater the chance for more serious problems with the weight and vibration.  Keep it as light and close to the head as possible, or your really going to have to brace it heavy duty style.
#24 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 23, 2015 - 05:37 AM
i like the stack concept ,even when i had mine on the rover , but the down fall i had was mine passed a little smoke now & then & that was a tad annoying to my eyes
#25 blacktruck OFFLINE
blacktruck
  • 30 Thanks
  • 57 posts
Posted June 22, 2015 - 08:26 PM
Bump to the top here. I tend to agree with this statement but as a person that has a pick up truck with stacks, I do have a weakness for them. If you think it looks good, go for the gusto and stack it. I haven't put one on a GT yet but one of these days, it wouldn't surprise anyone if I did.
#26 weekend_cutter OFFLINE
weekend_cutter
  • 12 Thanks
  • 14 posts
Posted June 22, 2015 - 11:27 PM
If you like stacks then do it. I have a stack on my Sears ST-16. Build it yourself and make a brace to take away the stress on your exhaust port and or exhaust bolts. If done right a stack will not damage your engine. They do get hung up on trees but it just lets me know when I have to trim them. Another thing to take into account is that you need to have your stack high enough to get the fumes out of your face. This can also be done if you use a exhaust tip that curves out and pushes the exhaust fumes away from you or a rain cap that opens away from you
#27 toppop52 OFFLINE
toppop52
  • 5,250 Thanks
  • 4,755 posts
Posted June 23, 2015 - 06:24 AM
My 4041 front end loader has a stack, just a piece of water pipe coming off the stainless muffler, which is about the only thing not rusty on the tractor, but I plan to turn it forward as I progress to fix the little things while using it all I can.
#28 Tankman OFFLINE
Tankman
  • 298 Thanks
  • 299 posts
Posted June 23, 2015 - 06:31 AM
I've had a few good stacks, grandsons "needed" the BIG tractor look.
I don't really have a preference but, mostly no stacks on my workers.
Edited by Tankman, June 23, 2015 - 06:33 AM.
#29 TAHOE ONLINE
TAHOE
  • 7,973 Thanks
  • 5,673 posts
Posted June 23, 2015 - 08:45 AM
no, that would be me  :D
I kind of like them, but I have way too many trees. I do have a project in mind down the road, may do it to that one.
  • David Brown and holdenboy1960 have said thanks
#30 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted June 24, 2015 - 07:55 AM
every 1 here should have at least 1 GT with a stack , including my self
it's like the man cave having a fridge
  • alec said thank you
