Bolens Tractor Complete Listing
18 replies to this topic
#1 chieffan ONLINE
  • 16596 Thanks
  • 9089 posts
Posted May 15, 2015 - 07:55 AM
Trying to locate a complete list of Bolens tractors with Model, Power size & mfg. and years of production. I have a list from TractorData but with with several omissions. There is no reference to same model types, like the G12XL being a 1255, etc. The super write ups on this forum are great but not in list form and was not meant to be for a quick look up. Also nothing has been mentioned about the medium frame XL series or the XT Tractors. Any suggestions as to where to look for this?
  • Paulgo said thank you
#2 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted May 15, 2015 - 09:56 AM
Jerome's garage.
  • wilberj and chieffan have said thanks
#3 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 15, 2015 - 10:21 AM
This will have everything up till 1987
http://www.ebay.com/...=item58c1380691
  • Husky, Alc and chieffan have said thanks
#4 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted May 15, 2015 - 10:58 AM
I've got that 1987 one and the 1996 one in pdf format if you want them.
  • chieffan said thank you
#5 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted May 15, 2015 - 11:00 AM
If you go here:
http://www.brentchal...MiscManuals.php
and down load the 1996 Garden Way Inc. Service Seminar Book, it will cover from 1949/1950 - 1996.
To save iot to your HDD, RIGHT click it and then choose the "Save target as..." option.
  • LPBolens, Bruce Dorsi and chieffan have said thanks
#6 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted May 15, 2015 - 11:07 AM
Only if all the info was right in them...
  • chieffan and Paulgo have said thanks
#7 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted May 15, 2015 - 11:10 AM
Yah, the serial numbers for the DGT 1700 were a bit off or should I say covered a wide range.
#8 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted May 15, 2015 - 11:14 AM
You get back into the 50s of those books the engines listed for the Ridemaster and Ride A Matic or not correct.
I have a half done spreed sheet done on bolens years I just had not had the time to work on it lately.
  • Husky, LPBolens and chieffan have said thanks
#9 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted May 15, 2015 - 10:46 PM
As Jerome said, some of the entries for the late 1940's and the 1950's are not correct in any of the Service Seminar books. As an example, the 35AA & 35AB Ridemasters are shown as having the Wisconsin BKN engine. That appears to actually be the factory authorized REPLACEMENT engine, not original equipment. To make matters worse, for years the Sonny's Bolens website used the same incorrect lists and was assumed to be gospel, so there is now a misconception out there.
#10 chieffan ONLINE
  • 16596 Thanks
  • 9089 posts
Posted May 16, 2015 - 06:30 AM
Yes, but a bit pricy if you ask me.  He's fishing and I don't swim very well.
#11 chieffan ONLINE
  • 16596 Thanks
  • 9089 posts
Posted May 16, 2015 - 06:35 AM
The part that is confusing for me is they have a model number of 1255 for example and it is listed at a G12.  Does this mean that a G14 with 14 hp Tech is a 1455?  Don't always shake out that way.
#12 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 16, 2015 - 06:59 AM
G14 is a 1453
Bolens always had two "Model" numbers for their 4 wheel tractors
#13 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted May 16, 2015 - 07:31 AM
It really would be nice to have an accurate searchable database.  I am constantly finding errors in the garden way catalogs and tractor data.com,  My searches have generally been limited to the 70's-80's medium frames, QT's, and HT's.
I have a QT16 with a 16 hp 2 cyl. Onan B43M that looks original.  A guy on youtube shows off his old, unrestored, "all original" QT16 with that engine too.  Garden way says they only used the BF-MS.
Tractor data says the HT23 uses 10 qts oil in the trans and 8 qts in the engine...
Paul
Edited by Paulgo, May 16, 2015 - 07:38 AM.
#14 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted May 16, 2015 - 09:15 AM
G14 is a 1453
Bolens usually or often had two "Model" numbers for their 4 wheel tractors. :smilewink:
#15 Bruce Dorsi ONLINE
Bruce Dorsi
  • 5122 Thanks
  • 2911 posts
Posted May 16, 2015 - 09:27 AM
As far back as 1977, Bolens said the QT-16's were equipped as the following:
1973 # 1666-01 used Onan BF-MS/2425A
1974 # 1666-02 used Onan BF-MS/2425B & /2425C
1975 # 1666-03 Used Onan BF-MS/2938D
1976 # 1666-03 used Onan BF-MS/2938D & /2938E
1977 # 1666-03 used Onan BF-MS/3283F
Is your QT-16 a later model?  ...Possibly this is where Garden Way got their info ?????
