1968 Bolens 850 governor spring tension setup
16 replies to this topic
#16 mgschwendtner OFFLINE
mgschwendtner
  • 1 Thanks
  • 11 posts
Posted June 01, 2015 - 07:25 AM
I replaced the governor gear and the governor control lever. The engine appears to be running better. The govenor sticking issue is gone and it operates smoothly. I mowed the grass once but nothing very taxing. I am going to mow a steep grade a neighbor has once it dries up this week. That will be the true test as it would bog down and then overspeed at the top of the incline.
The new style govenor wasn't metal as the previous part number was, some type of nylon plastic, similar to a starter gear.
#17 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 01, 2015 - 07:28 AM
Later year gov. gears were made of a Nylon type material.
Just remember not to be on an angle too long while mowing as these are splash type lubrication.
