I have looked at lots of pictures online of how people have setup their governor linkage and mine is drooping quite a bit on the points cover. I will attach pictures of my setup, throttle is set at idle. I am not satisifed in how it currently operates. It has a habit of surging way over 3600 when i go full throttle and then settles back down. I play around with it and it doesn't behave how i expect that it should operate. This engine was rebuilt completely .10 over.
For all of those who noticed, why yes that is a brand new zenith carb purchased directly from Zenith. I spoke with a parts guy when I inquired about a new carb, he said the S8D's were no longer avalable, but I could order one for a S7D and change out the main jet with the correct one for a S8D.
Do you go for 3600 RPM for full throttle and what do you use for idle?
Thanks!
