Hydro fluid in HD12
2 replies to this topic
#1 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted May 14, 2015 - 06:21 PM
What fluid should I put in my HD12? And what is the fluid level my has got a elbo with a plug in it on the right side of the transaxle? Thanks for your help Jake
#2 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 14, 2015 - 06:41 PM
Transmission fluid- I don't think it matters- my memory is dextrin-mercon - I buy the larger containers- if you are changing fluid there is a filter screen you will want to pull out and make sure it's not clogged-it's in the hole you drain the fluid out of- may take a small hook to pull it out or may can pull it out with your small finger- I usually just make sure the fluid is fairly full but not over flowing- some of other guys may can add more to this info.
  • Jake said thank you
#3 olcowhand ONLINE
  • 41,134 Thanks
  • 31,413 posts
Posted May 14, 2015 - 06:45 PM
Just fill to top of elbow. I use dexron III in mine but you can use straight 30wt motor oil, or a quality hydraulic/transmission oil. Do NOT use straight hydraulic fluid.
  • Jake and Texas Deere and Horse have said thanks
