1477 sinking into the ground
34 replies to this topic
#1 MH81 OFFLINE
Posted March 25, 2011 - 05:57 PM
I stumbled onto a pretty rough 1477 today, missing carb, sunk into the ground a little, doesn't look like it's moved in a while... and me without my camera. Lady didn't know much about it, husband would be home later. Any ideas on what I'm getting into? Known Weak spots (I know Doc... it's a Bolens, thus NO weak spots LOL) Are they worth much running? it says Hydrostatic on it BTW.
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted March 25, 2011 - 06:02 PM
I'd grab it for under 300 bucks and pop a carb on it. Was it a techumseh?
#3 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted March 25, 2011 - 06:57 PM
they are good tractors has a 14hp wisconsin hydro.It has the eaton 12 hydro and one of the best IMO.Only problem i can think of is the wisconsin uses a soild state and can be hard to find.If the price is right i would get it.Does it come with anything?
#4 Bolens 1000 ONLINE
  • 14,983 Thanks
  • 18,140 posts
Posted March 25, 2011 - 07:30 PM
:ditto:
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted March 25, 2011 - 07:33 PM
:ditto:
Watch out using those :ditto: 's, they can get pruned lol. (Couldn't resist Alan lol)
#6 MH81 OFFLINE
Posted March 25, 2011 - 07:39 PM
I did speak with the gentleman tonight. Said the throttle shaft broke & he couldn't find one. "Been a couple of years". As for what's with it, he said it had a 48" snowblower that was a little too big for it, and a mower deck. I didn't see either of those. He said he still has the carb & the broken shaft in the shed. He's gonna talk to the wife & call me back with a starting number. We'll see if it goes anywhere.
#7 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted March 25, 2011 - 07:48 PM
Alan did forget to tell you the most important thing that goes wrong with them.It is once you get a bolens large frame you can't stop and want another one lol.
#8 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted March 25, 2011 - 08:01 PM
The 1477 the last of the short large frames built in only 1971 it was powerd by a 14HP wisconsin with a Eaton 12 hydro.
They go for around $500 give or a take $100.
Edited by wilberj, March 25, 2011 - 08:29 PM.
#9 Bolens 1000 ONLINE
  • 14,983 Thanks
  • 18,140 posts
Posted March 25, 2011 - 08:05 PM
Here's a brochure pic
#10 grand OFFLINE
grand
  • 2,037 Thanks
  • 2,013 posts
Posted March 25, 2011 - 08:12 PM
Thanks for the picture Brian. I look at that and wish that I could step back in time and climb aboard that great looking machine and start mowing grass.
#11 EricFromPa OFFLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted March 25, 2011 - 10:24 PM
Doesn't the S14D have the same engine block as the S12D on the 1250?
If so it has points and condenser and not a Solid State ignition module.
1477 manual here.
http://gardentractor...035d222272fa875
#12 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted March 25, 2011 - 10:29 PM
1477 manual here.
I was changed over in the 1455 and newer.
#13 MH81 OFFLINE
Posted March 25, 2011 - 10:31 PM
There was something near where the carb went on that said "Solid State Ignition" It was about 2 inches long by 1.5 wide, 3 wires.
Also, Hood was Black? I think? A lot more Black than the cat pic above.
There was a PTO shaft coming thru the front axle, if that helps.
Bob: :bigrofl: Thanks for the warning.
#14 daytime dave ONLINE
  • 4,833 Thanks
  • 6,539 posts
Posted March 25, 2011 - 10:47 PM
Good luck on it.
#15 mjodrey OFFLINE
Posted March 26, 2011 - 05:24 AM
good luck on it.
ditto !!
