57565 Brush saw / 57590 Weedcutter Rebuild / 57567 Cordwood Saw
42 replies to this topic
#31 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 10, 2015 - 08:06 PM
The fellow I talked to the other day at Fastenal about getting the 9/16" rod never called me back so I found a 1/2" rod and make it out of that . Of course once it was on the saw I needed to try the saw out.To be honest I was apprehensive the first time that 20" blade started to spin ! OK the dry run was over then headed over to the garden where  I had some small branches that fell from the trees that are a pain to cut with the chain saw . Even though the blade should be sharpened it did quick work on most except for the dried 4" + ones .  The biggest problem is the carb needs adjusting/cleaning wouldn't keep steady speed.
  • wvbuzzmaster, KennyP, shorty and 1 other said thanks
#32 KennyP ONLINE
  • 37,542 Thanks
  • 45,531 posts
Posted June 11, 2015 - 05:19 AM
Glad to see you got it working. We had a similar saw when I was growing up, just a much bigger table for the logs to lay on. I'm thinking it was close to 6' long, but that was a long time ago.
#33 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 11, 2015 - 05:42 AM
Kenny , I wouldn't want to put too big of pieces on this but for the smaller stuff it seems easier ( and safer )  then holding a branch with one hand and using the chain saw in the other .
#34 KennyP ONLINE
  • 37,542 Thanks
  • 45,531 posts
Posted June 11, 2015 - 07:12 AM
Ours was just bigger over all. That blade was probably 30-36" dia. But it kept us warm! Sharpening the blade will probably help a lot. Have fun with it.
#35 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted June 11, 2015 - 11:04 AM
Glad to see you got it going! It looks like you even have the original pulley for it. Can you tell me what size pulley is running the saw?
Thanks!
#36 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 11, 2015 - 11:17 AM
Which pulley ? The one on the jack shaft or mandrel  ( I call it an arbor)  ?
#37 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 12, 2015 - 09:06 PM
Figured it was just as easy to get both along with some pictures . Both pulleys are 3 1/2" OD The pulley on the jackshaft has a casting # 8004M, just a keyway and square headed setscrew to hold it on . The one on the arbor or mandrel has 8007M cast on it . I didn't have that one off but the shaft has a keyway ,a square headed  setscrew ( strange it doesn't line up with the keyway ) also a grease fitting
  • KennyP and VSTROM803 have said thanks
#38 KennyP ONLINE
  • 37,542 Thanks
  • 45,531 posts
Posted June 13, 2015 - 05:30 AM
Wonder if a set screw was supposed to be where the zerk is?
#39 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 13, 2015 - 06:15 AM
Kenny never thought of that. That pulley i didnt remove yet its held on by a caslated nut that's where you can adjust the taper bearings in the mandrel . I noticed the cotter pin is gone now ,thought there was one so I'll take the nut off and get a better look
#40 KennyP ONLINE
  • 37,542 Thanks
  • 45,531 posts
Posted June 13, 2015 - 07:53 AM
Or that may be to lube between the pulley and housing.
#41 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 13, 2015 - 08:20 AM
Took the nut off, it didn't look like there was a cotter pin in for some time , the set screw just contacts the round smooth part of the shaft , and the grease fitting is drilled to grease the taper bearing . took a few pictures before putting it back together
#42 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 14, 2015 - 12:59 PM
I measured the 3 groove engine pulley the center groove that runs the saw is 3" OD . This pulley was mounted on the tractor the came with the saw . I removed it and installed it on the Super Power ( same model )  I also measured the 4 groove pulley thats on the DB 600 ,, 3 1/4" OD I'm not sure if that pulley would be used on this saw or not
  • VSTROM803 said thank you
#43 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted June 17, 2015 - 07:56 AM
I think I made a mistake when I drill the hole in the clutch rod , the way I have the handle in the " OFF" the weight of it applies against the yoke . I had to straighten  the slight bend in the rod that's about a foot from the attaching point , then put the bend back with the handle vertical and redrilled the hole in it's new position . Here's the way it looked before ,didn't get new pictures yet .
