New Problem on my 1920 Ultima
2 replies to this topic
#1 toppop52 ONLINE
toppop52
  • 4,379 Thanks
  • 4,132 posts
Posted May 10, 2015 - 08:42 PM
When I'm mowing, the longer I mow, the more this happens. It will suddenly turn off the pto clutch as voltage drops to near zero, then it will start to surge and usually start charging and go back to normal. I also notice that it appears to have weak fuel pump and the flow is weak. Fuel will boil a bit in the filter like a vapor lock condition, but that doesn't explain the voltage drop before the running gets rough. I'm wondering if the pto is somehow shorting or some other short exists. These tractors being similar to Massey, Simplicity, etc... I thought maybe someone had run into this.
#2 UncleWillie ONLINE
  • 14,213 Thanks
  • 8,182 posts
Posted May 11, 2015 - 10:38 AM
If the fuel is boiling then the motor is not making enough power to run the pto most likely. Pull the tins off the engine and see if there is a rat condo in there.
  • toppop52 said thank you
#3 toppop52 ONLINE
toppop52
  • 4,379 Thanks
  • 4,132 posts
Posted May 11, 2015 - 07:33 PM
I guess that could be. I'll look into it.
