Whining noise when turn key and won't start
d110 lawn mower
7 replies to this topic
#1 Freddiek0827 OFFLINE
Freddiek0827
  • 1 Thanks
  • 1 posts
Posted May 10, 2015 - 08:40 PM
i have a john Deere D110 lawnmower with 62 hours on it. I just changed the battery due to not starting. Before changing battery it would turnover but not start. After I changed the battery I turn the key and get nothing but a whining noise.what could be wrong?
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 10, 2015 - 08:55 PM
Did you hook up the new batt backward. Not trying to insult you but it happens to the best.
Mike
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 10, 2015 - 09:30 PM
How old was the battery the store sold you?  How big is it in CCA's?
Sounds like the starter is not getting enough amperage to spin the engine, but enough voltage to click the solenoid.
Ben W.
#4 boyscout862 OFFLINE
  • 12,535 Thanks
  • 9,034 posts
Posted May 10, 2015 - 09:32 PM
Welcome to GTT. The whinning is probably the starter spinning but the Bendix gear not engaging. This could be that it is sticking or that the motor is spinning backwards(see above). Good Luck, Rick
#5 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted May 10, 2015 - 10:15 PM
Couple things could be wrong here. It mostly sounds like you don't have enough juice, or your starter is worn out. Sounds like the bendix is engaging the flywheel, but it's not turning over. The solenoid should be fine cause we hear a noise when the key is turned. Remove the power wire to the starter and turn the key. If you hear a click we've ruled out the solenoid for sure.
#6 farmer john OFFLINE
farmer john
  • 1,762 Thanks
  • 895 posts
Posted May 10, 2015 - 10:30 PM
are you sure the whining isnt coming from you because your not getting any seat time. ha ha ha!!!!
  • LilysDad and HANKG have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted May 10, 2015 - 11:14 PM
Check the starter by taking it off and energizing it on the work bench. see if the Bendex is coming out, use Graphite to lubricate the Bendex if needed.
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 11, 2015 - 07:30 AM
Did you check the "new" battery?
