craftsman II deck belt size
8 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted May 09, 2015 - 11:32 PM
does anyone know the size of a craftsman II 44 inch deck belt? mine shredded so its kind of hard to go from there, this is probably a 20 yr old machine, thanks john
#2 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,991 Thanks
  • 4,410 posts
Posted May 09, 2015 - 11:54 PM
Does yours have a horz engine with a mule drive, or a vert engine?
  • farmer john said thank you
#3 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,991 Thanks
  • 4,410 posts
Posted May 09, 2015 - 11:58 PM
Hulks deck belt has these stamped on it "110884X HBD 124"
#4 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted May 10, 2015 - 01:38 AM
vertical motor
#5 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted May 10, 2015 - 07:28 AM
On the 917.254450  & 917.255460 vertical shaft tractors, it shows a 106085X belt for both the deck and drive belts. This is a NAPA 4L790W belt, 1/2" X 79". Don't know which Craftsman II you have!
Larry your 110884X belt converts to a NAPA 4L930W. 1/2" X 93".
#6 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,991 Thanks
  • 4,410 posts
Posted May 10, 2015 - 10:13 AM
Thanks Kenny, Hulk II is a horizontal 917.255919, the deck is stored so it was easy to get the belt number. RED is a 917.254450 and it looks like I got the belt for it at Tractor supply, Huskey belt 1/2 X 92" and a 1/2 X 94" not sure which I used where. edit: I tend to exchange belts a lot at T/S till I get the one that fits, so the receipt info above may not be correct.
Edited by larrybl, May 10, 2015 - 10:15 AM.
  • KennyP and farmer john have said thanks
#7 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted May 10, 2015 - 10:33 AM
Not having a model for the tractor makes it hard as Sears changed things often!
#8 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted May 10, 2015 - 10:26 PM
I have looked all over this tractor for a tag, no such luck, after piecing the old belt together I come up with 77 1/2 so I think kennyp numbers may be correct I will go and get a 79" one and go from there. let the games begin, thanks all john
#9 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,991 Thanks
  • 4,410 posts
Posted May 11, 2015 - 06:38 PM
Tag is supposed to be on the fender pan under the seat. My method when in doubt is to guess at a size and purchase from Tractor Supply, keep the receipt then exchange till one fits.
