Need to replace cylinder rod on Case 444 3PH
3 ph case 444 3 point hitch cylinder repair hydraulic cylinder
18 replies to this topic
#16 MNGB ONLINE
MNGB
  • 1,969 Thanks
  • 1,334 posts
Posted May 11, 2015 - 06:55 PM
Hi  Utah Smitty, I measured an Ariens GT14 lift cylinder but its long at 15" overall (4 inch stroke) and an OD of 2 1/8",  My Power King 3 pt cylinder is closer but still a bit long at 14.5" overall length with a 4 inch stroke and an OD of 2 3/8". I guess if you can't find the parts to repair the original Case cylinder a PK one could be made to work.
  • Utah Smitty said thank you
#17 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 12, 2015 - 12:19 AM
Thanks for checking that out.
I took the cylinder to a hydraulics shop today.  The replacement shaft was slightly bent, and had some dings in it, so he's going to make me a new one and hook it up to the existing piston, plus add new seals.  He even has a source for the top wiper seal for about $6.00 so that's better than $15 some places charge... I should have the piston back Wednesday.
BTW, could you measure the lift arms on the Ariens GT14 for me?  I want to put a set on my GT20---it's using the Case lift arms right now--, but I don't know what size the Ariens arms are.
Thanks,
Smitty
#18 MNGB ONLINE
MNGB
  • 1,969 Thanks
  • 1,334 posts
Posted May 12, 2015 - 12:52 PM
Hi Smitty sound like you found a good shop and will have you back in business, sorry I sold the Ariens about a yr ago otherwise I sure would measure them.
#19 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 13, 2015 - 01:01 AM
Thanks for your input.  I'm excited to get the Case 444 hitch finished.  I have another dual spool Case valve, and a Case flow control valve.  I'm thinking of adding them so I can have an independent 3ph hydraulics, and also have hydraulics to the rear and front.  Shoudn't be too hard to setup I wouldn't think.
Smitty
Also tagged with one or more of these keywords: 3 ph, case, 444, 3 point hitch, cylinder repair, hydraulic cylinder
