Scored this lot today
12 replies to this topic
#1 poncho62 OFFLINE
poncho62
  • 1,980 Thanks
  • 1,735 posts
Posted May 09, 2015 - 05:09 PM
Its a LGT165 and 145.....I forget how to look up the year, is it the serial number or engine number?
  • Bolens 1000, olcowhand, DH1 and 16 others have said thanks
#2 oldedeeres ONLINE
oldedeeres
  • 10,276 Thanks
  • 5,019 posts
Posted May 09, 2015 - 05:36 PM
   Looking good! Let's just hope you won't be needing the snow blower 'til Dec.  Nice haul.
  • tinbender7 and boyscout862 have said thanks
#3 boyscout862 OFFLINE
  • 13,428 Thanks
  • 9,379 posts
Posted May 09, 2015 - 05:52 PM
Those "open sides" are early 70s. Congratulations they are great tractors. You will enjoy them when they are running right. Good Luck, Rick
  • tinbender7 said thank you
#4 IamSherwood OFFLINE
  • 8,395 Thanks
Posted May 09, 2015 - 05:59 PM
Congrats. Nice haul.
Those are the two from Wiarton, right?
I saw that ad, and thought it was a deal too.
  • poncho62, tinbender7 and boyscout862 have said thanks
#5 KennyP ONLINE
  • 40,023 Thanks
  • 46,722 posts
Posted May 09, 2015 - 06:06 PM
Nice score there! Use the engine serial for year. Nothing documented on the chassis serial as yet.
#6 poncho62 OFFLINE
poncho62
  • 1,980 Thanks
  • 1,735 posts
Posted May 09, 2015 - 06:18 PM
Yep...them's the ones.
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,291 posts
Posted May 10, 2015 - 04:06 AM
Lorna said it all! Thank you, Lorna.
  • oldedeeres said thank you
#8 poncho62 OFFLINE
poncho62
  • 1,980 Thanks
  • 1,735 posts
Posted May 14, 2015 - 06:19 PM
Had the 165 running yesterday, smoking a bit. Its been sitting outside for a year or two....hope that clears up
  • DH1, KennyP and Rock farmer have said thanks
#9 poncho62 OFFLINE
poncho62
  • 1,980 Thanks
  • 1,735 posts
Posted June 07, 2015 - 05:15 PM
Got the "parts" tractor running today......I wanted to see if it was better than the 16hp one.....Had to pull the head as the valves were sticking. Got them loose, cleaned all the mouse nest out of the fan area, put it back together with the old head gasket. There is one broken head bolt, which I will deal with when I pull the head again to change gasket. It runs pretty well, hardly any smoke. I am going to take the tin work from one of my 125s to get this one presentable....nice to have the hydraulic lift, which works good.
As for the 165, it's still smoking like an old factory......I am going to rebuild the engine when time presents itself
#10 poncho62 OFFLINE
poncho62
  • 1,980 Thanks
  • 1,735 posts
Posted June 08, 2015 - 05:28 PM
Tore down the 16 hp engine this morning......has a 020 piston in it, thats real sloppy, so we are going to bore it 010 more. Also, a new rod and probably go under on the crank. The balance gears are also real sloppy, so they will be getting pulled.....I cant get the flywheel off with my puller, so my buddy at the machine shop will be tearing the crank and rest of guts out of it.
One thing....I went to take the governor shaft out and it wouldnt come out.......I thought it should just slide out...Any thoughts on this?
#11 poncho62 OFFLINE
poncho62
  • 1,980 Thanks
  • 1,735 posts
Posted July 05, 2015 - 04:37 PM
Managed to get my Ford family together today for a family photo......Big brother 165 couldnt make it, is in the hospital awaiting a transplant.
The rest of the family is here.......please ignore the green haired step child on the left, he snuck into the picture
Back in the barn for the night
Junkyard
  • Alc, sacsr and skyrydr2 have said thanks
#12 Alc ONLINE
  • 7,112 Thanks
  • 7,526 posts
Posted July 05, 2015 - 05:22 PM
Nice collection ! You going to paint that green one Ford Blue so it doesn't feel of of place ?
  • poncho62 and KennyP have said thanks
#13 KennyP ONLINE
  • 40,023 Thanks
  • 46,722 posts
Posted July 05, 2015 - 05:55 PM
Nice collection. til I got to that green one! Better bleach it to get rid of the mold!
  • poncho62 and skyrydr2 have said thanks
