MTD White
briggs
9 replies to this topic
#1 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted May 08, 2015 - 03:33 PM
Hi guys, I'm working on this machine. He just bought it,has no hood on it and he was told it's a 23 hp Briggs in it. It fires all the time. And will run with gas poured into carb. This has a 2 prong plug in the bottom of bowl. I've cleaned the carb twice now and no better. Can someone tell me what this thing does? Or if I'm overlooking something?
  • Sawdust said thank you
#2 KennyP ONLINE
  • 40,975 Thanks
  • 47,146 posts
Posted May 08, 2015 - 04:00 PM
That plug in the bottom of the bowl is a solenoid that cuts the fuel to the engine. If it is bad, no fuel to start it.
#3 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted May 08, 2015 - 04:05 PM
Check for power to the carb solenoid. They can be a pain, Noel
#4 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted May 08, 2015 - 04:35 PM
Yup. I just traced it back to the relay and it's a pile of rust inside. So I'm  off to see if I can get one tonight as of yet!
#5 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted May 08, 2015 - 06:01 PM
Well no one open don't carry these relays. Go figure. Just my luck. Thanks for the help guys.
#6 drbish ONLINE
drbish
    Collecter
  • 1,575 Thanks
  • 1,372 posts
Posted May 08, 2015 - 06:07 PM
I have not done it but was told you can eliminate the solenoid,
#7 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted May 08, 2015 - 06:58 PM
Hmmmm. Interesting. I wouldn't know,there are 4 wires going into it. Never worked on anything this new.
#8 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,446 Thanks
  • 5,621 posts
Posted May 08, 2015 - 07:14 PM
You should be able to remove the solenoid from the carb and put a plug in it, like what's used on carbs that don't have the solenoid.
I have cut the end off the plunger on the solenoid with side cutters so that the fuel flows all the time.
  • limebuzz said thank you
#9 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted May 08, 2015 - 07:18 PM
Thanks for the tip Doug.likw I said,this isn't my machine. So I better run it by the owner before I go hacking it up.
#10 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted May 09, 2015 - 09:43 AM
Well,went and got a new $26 relay and she's up and running now. Thanks for all the help.
Also tagged with one or more of these keywords: briggs
