Mower power not consistent
24 replies to this topic
#16 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 01, 2015 - 08:09 AM
#17 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted June 01, 2015 - 07:49 PM
This must be the 48" deck?
#18 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 02, 2015 - 06:34 AM
yeah 48"
everything spins freely so I think once I clean it off and get the blades sharpened it should be ready to rock
#19 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 02, 2015 - 06:36 AM
What I didn't realize originally is that the larger decks use 4 true hangers and a lift arm connection, whereas the smaller 38" deck just uses the front 2 and a chain hanging from the lift arm
#20 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted June 02, 2015 - 07:14 AM
I looked at that deck again and thought it looked odd. Then I realized we were talking YT models here, not LGT! :wallbanging:
  • aevansgatech said thank you
#21 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 04, 2015 - 06:31 AM
Ok big day yesterday. I swapped the 38" deck off and put the 48" on
It does work and I mowed the back yard, but still something is not quite right. I can't lift the thing up using the lift arm!
I believe the rear hanger is either on wrong or my connection to the lift arm isn't right.
Front hangers
I'm fine with leaving it down all the time, but I'd like to be able to lift it and on top of that I can only raise the cutting height to about halfway. Something is hanging up! Thoughts?
#22 MH81 OFFLINE
Posted June 04, 2015 - 06:43 AM
If you lift it and assist it, does it lift all the way?
#23 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted June 04, 2015 - 07:01 AM
I just looked in the mower manual and I can't tell if you have the lift link (bent rod) in the right hole (page 16, item J). The instructions are a bit vague without seeing the parts in person.
#24 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 04, 2015 - 07:50 AM
Yeah I tried putting it in both holes but same restriction
I think part of the problem is the rusty chain links are binding up on each other really bad which is restricting movement, but aside from that it looks like it should rotate the rear hanger assembly and lift the dual chains when I pull the lift arm.
Maybe put some grease on the chain?
#25 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted June 04, 2015 - 08:50 AM
Hmm ok I'm pretty sure I found the issue. Comparing the manual pic and my rear hanger pic, I have the hanger rotated too far. I'm essentially trying to pull the chain arms forward rather than backwards. I think I can fix this tonight!
