John Deere Check Valves
2 replies to this topic
#1 oliver2655 OFFLINE
  • 37 Thanks
  • 82 posts
Posted May 07, 2015 - 09:44 PM
Are the check valves from the 300 series tractors interchangable with the ones in my 120? i am in search for some new ones as mine are leaking oil from the buttons on top. i seen one pair without the buttons on top and wondered if i could get away with running those so i dont have to worry about the leaky buttons? Thanks for anyones help!
  • laurarg3 said thank you
#2 Trav1s ONLINE
  • 3,405 Thanks
  • 4,430 posts
Posted May 07, 2015 - 09:56 PM
Yes they are the same.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 08, 2015 - 07:37 AM
I think the 120 was the first JD to use the Dana/sundstrand transaxle. All the 300s up to the introduction of the 318 used the same setup. The later 140  ser. 30000 and up also used the Dana setup.
  I think you can get those valves and other transmission parts from a Sundstrand dealer new for a lot less than JD sells them for. Somewhere I think I saw that new  valves are only 50$ ea when purchased this way. I have a 314 that has had them replaced at one point. My 317 has one that sticks and the button is chewed up where it looks like someone put a set of pliers on it to pull it up.
