Choremaster Help Please
1 reply to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted May 06, 2015 - 06:06 PM
I need to make a new gasket for the gear cover on my Choremaster.
It is part # V-1009...I don't expect to find a new gasket, but if anyone knows how thick this gasket is, I would appreciate knowing.
I can get gasket material in 1/64" and 1/32", and thicker.
I used a "mic" on the old (shot) gasket and it was 0.01", but could have been "squeezed" some. 1/32"  is 0.03125, therefore 1/64" would be 0.01562.
The main reason I am asking for the thickness is this cover also helps support the axle shaft and I don't know if a thicker gasket would cause problems.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 06, 2015 - 09:39 PM
1/64 paper with gear oil sealant is what I used on one according to my notes.
I will reproduce a couple to have on hand when I get another tractor in to borrow as a pattern.  They don't really fail, but if you do a quality rebuild you should clean up the gear box.
Ben W.
  • DougT and KC9KAS have said thanks
