Pincor 2 kw generator - $25 (Plainfield CT)
12 replies to this topic
#1 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted May 06, 2015 - 05:39 PM
I just went and got this. Very nice guy who understands the hobby. He collects outboard motors from pre 1960. We had a good visit.
I hope this will match with my 725. Good Luck, Rick
Pincor 2 kw belt drive generator. No engine.
  • Alc, trowel, Talntedmrgreen and 5 others have said thanks
#2 Sdhdcouple OFFLINE
Sdhdcouple
  • 147 Thanks
  • 153 posts
Posted May 06, 2015 - 05:44 PM
mount that to the front of a tractor.
#3 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted May 06, 2015 - 05:47 PM
Rear actually,
Nice find Rick ! do you have the mounting frame for it ?
#4 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted May 06, 2015 - 06:18 PM
Rear actually,
Not even the manual for this one. It is mounted to a steel dolley where it was direct connected to an engine. I will try to find what the missing pieces look like.
I have a different shaped 2kw that goes to my choretrak 2 wheeler. Good Luck, Rick
#5 Talntedmrgreen ONLINE
  • 3,293 Thanks
  • 2,320 posts
Posted May 07, 2015 - 04:23 AM
Dang....thats dirt cheap! Ive been watching for any old genhead to paint up and make a blue genny for my Homelite and NOTHIN has been that inexpensive.
The Pincors never had a factory Simplicity application that I am aware of, but the Generacs that did have an awful simple mounting setup.
You may be best suited making a base and tension rod like that of the early style (1500w) generator setup vs the late style which would require much more fabrication.
Any pics of the Choretrak/generator?
#6 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted May 07, 2015 - 05:04 AM
I agree with Josh, the early version mounting bracket is simpler. Josh, if you could, you should upload the diagram of the set up, I do not have any pictures or anything scanned that could help.
Rick, I had several pictures of homebuilt set ups for the early Landlords but the comp virus forced me to delete everything. Most everything was found on the open net so it is searchable. If you are thinking of building a electrical enclosure with gauges I would like to guild you through it, I have built several for gensets and testing applications.
#7 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted May 07, 2015 - 07:26 AM
Nice looking generator at a great price. With a 2Kw rating you may be able to lower the speed of your engine and adjust the pulley ratio to get the correct generator speed/frequency. By doing that you will reduce noise, fuel consumption and wear and tear on your tractor engine and still be able to get the full 2kw of power, which only requires about 4hp maximum. You do need some way to measure and set the speed though. Some of the high efficiency generator setups I've seen run the engine at around 2500rpms to get maximum fuel economy.
  • trowel and boyscout862 have said thanks
#8 Talntedmrgreen ONLINE
  • 3,293 Thanks
  • 2,320 posts
Posted May 07, 2015 - 01:29 PM
Attached are the early Generac parts diagram for Simp/AC, and here is a pic of it mounted up.
I'd suggest running it off the more standard, LH side of the BGB.  Front mount would probably be really simple too.  Seems to be what all the other GT makers did.
  • JDBrian and boyscout862 have said thanks
#9 Talntedmrgreen ONLINE
  • 3,293 Thanks
  • 2,320 posts
Posted May 07, 2015 - 01:32 PM
Here is a pic of the 5000w mounted, and the diagram of the mounting components
  • JDBrian, boyscout862 and Sawdust have said thanks
#10 boyscout862 ONLINE
  • 13,693 Thanks
  • 9,476 posts
Posted May 07, 2015 - 04:07 PM
Its buried in the back of the basement. I'll try to dig it out in the future and post some pics. I even have the legs that attach to the front of the two wheeler to hold it, somewhere. Good Luck, Rick
I thought that this was a Simplicity attachment. I know that I have seen one of these as an attachment for an old GT.
Edited by boyscout862, May 07, 2015 - 04:12 PM.
  • JDBrian and trowel have said thanks
#11 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted May 07, 2015 - 04:15 PM
Thanks for the pics guys. I think a gen head could be mounted to most brands of tractors with a belt drive PTO front or rear. It would be a real handy thing to have for backup power or for a portable generator that you could take to remote locations.
  • trowel, boyscout862 and alec have said thanks
#12 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 07, 2015 - 06:54 PM
just make sure you mount it to the front pto so it works when your bgb fails :poke:
#13 Talntedmrgreen ONLINE
  • 3,293 Thanks
  • 2,320 posts
Posted May 08, 2015 - 07:50 AM
Front mount Pincors...
  • boyscout862 and alec have said thanks
