Does anyone know the proper name for this hinge?
9 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 06, 2015 - 06:22 AM
We are using this hinge in an application at work and nobody seems to know the proper name for it.  We don't often use stuff like this in what we do so this is a first for us.  We are referring to it as a double acting hinge but something tells me that's not right.  If I do a search for a double acting hinge, nothing comes up.  Would like to find some design info on it because the sample you see below is over a thousand miles from me and I don't feel like going to pick it up.  Thanks.
  • Bruce Dorsi said thank you
#2 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted May 06, 2015 - 07:03 AM
Check a catalog like "Woodcraft" or similar. Good Luck, Rick
  • David Brown said thank you
#3 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted May 06, 2015 - 07:21 AM
I googled 'Double Pin Hinge' and found all this.
Clicked on this link and it may be a multiple pin hinge.
Edited by KennyP, May 06, 2015 - 07:23 AM.
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 06, 2015 - 07:28 AM
Thanks Kenny.  Looks like double pin hinge is the most common name.  Makes sense.  Guess I was stuck on the "action" more than the double.
#5 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4,008 Thanks
  • 2,485 posts
Posted May 06, 2015 - 07:56 AM
Very interesting !!
A double-acting hinge will allow a door to swing in either direction inside the jamb.  ...The hinge pictured does not appear to allow that.
Looking at the way the hinge pivots, a door could swing out and away from the jamb, allowing an unobstructed opening.  ....This style of hinge is often referred to as a "swing clear" hinge.
Your pic appears to be of a bronze casting with stainless(?) pins.  .....This suggests a marine application???
Please let us know what you find out.
  • KennyP and David Brown have said thanks
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 06, 2015 - 10:43 AM
The "hinge" :poke:
#7 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 06, 2015 - 10:46 AM
Very interesting !!
Yes, it is a bronze hinge but it's not a marine application that I know of.  They are for a hatch in a grating area.  Not sure why they want bronze but the customer is always right!
#8 Bill 76 ONLINE
Bill 76
  • 2,015 Thanks
  • 1,208 posts
Posted May 06, 2015 - 02:50 PM
Maybe made out of bronze so it won't rust or perhaps for use in a flammable location so there is zero chance of a spark.
#9 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,335 Thanks
  • 10,293 posts
Posted May 06, 2015 - 02:53 PM
What does your supplier call it?
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted May 06, 2015 - 04:02 PM
Well I didn't order it and since I work all by my lonesome over a thousand miles away, I don't know and I'm not asking.  My guess is they simply called it a hinge.
