sears ff18 three point moving slow
8 replies to this topic
#1 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted May 05, 2015 - 06:09 PM
my three point and front lift are moving real slow.if i put 100 to 150 pounds on back it won't lift.new fluid and new filter.besides that the tractor runs and moves fine.i am out of ideas.
  • laurarg3 said thank you
#2 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 05, 2015 - 06:58 PM
Everything was good until the oil & filter change? Are you sure it is full? It took me forever to get my FF20's full again.
#3 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted May 05, 2015 - 07:09 PM
i can see the fluid in the hose in the back.when i got it it was dry because he had the wrong filter on it .i got the real filter and filled it up .about 5 quarts.it moves but slow?
Edited by Tomwendt, May 05, 2015 - 07:11 PM.
#4 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 05, 2015 - 07:40 PM
I hope it's a simple solution. If it's full, then I have no other help. But it sure sounds like it is low.
#5 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted May 05, 2015 - 08:41 PM
if the line is full do keep dumping it in?
#6 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 06, 2015 - 06:15 AM
I had to take the fender pan off mine and get down to the vent hose that goes to that canister. Unhooked that hose (at the canister) to let the air out as the canister vent is real slow letting air out. If you did not remove that hose, there is the possibility you don't have enough fluid in it. How much did you get in it? Should hold close to 2 gallons.
Edited by KennyP, May 06, 2015 - 07:30 AM.
Edited capacity.
#7 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted May 06, 2015 - 06:56 AM
They hold all most 2 gallons if I recall, can you get to the checking plug at the back???
If you take that out and fill it until it glops out, replace the plug and give it an extra cup, you should be just fine.
#8 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 06, 2015 - 07:30 AM
You can't get to that fill/check plug, Keith. It has the fill tube hooked to it. The vent at the top is hooked to a canister by a hose.
I don't remember how much I put in mine, the manual says 7-1/2 qts.
  • skyrydr2 said thank you
#9 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted May 07, 2015 - 06:48 PM
i need to rebuild my charge pump.75 lbs. pressure.should be 500-600.
