Guess what caused this!
27 replies to this topic
#16 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,574 Thanks
  • 2,107 posts
Posted May 05, 2015 - 06:49 PM
mouse urine
  • alec said thank you
#17 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
If I had posted this here in the Mechanical & Hydraulics forum that KennyP guy would have moved it to the eletrical forum  :rolling:
HUH?
#18 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted May 05, 2015 - 06:52 PM
Okay! Here ya go! The PO had hooked one of the stator wires to the B+ terminal. Found that when I tore it down. The regulator mounts on the firewall with the connections down, so you can't see how thing are hooked up.
  • superaben said thank you
#19 HANKG OFFLINE
HANKG
  • 6,198 Thanks
  • 3,381 posts
Posted May 05, 2015 - 06:53 PM
Loose wire touching shorting it self out ?
#20 Jack ONLINE
Jack
  • 1,271 Thanks
  • 850 posts
From the looks of the corrosion on the connector blades my guess is high resistance caused the connections to overheat.
#21 Jack ONLINE
Jack
  • 1,271 Thanks
  • 850 posts
Posted May 05, 2015 - 06:56 PM
I guess I should have refreshed the page before I made a post.
#22 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted May 05, 2015 - 07:33 PM
The stator seems to be okay according to the ohm meter. I'm sure that AC voltage going into a DC output did wonders to the insides!
  • boyscout862 and superaben have said thanks
#23 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 05, 2015 - 09:56 PM
And that was the start of a famous and expensive boo-boo!
Are you going to need a new one, Kenny?
Ben W.
#24 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted May 06, 2015 - 05:53 AM
Ben W.
Not sure what the engine will be going back into. Would one of the newer smaller regulators work here?
#25 TAHOE OFFLINE
TAHOE
  • 7,811 Thanks
  • 5,611 posts
Posted May 06, 2015 - 07:54 AM
I've replaced two of those Kenny using the newer small type like used on the newer Onans, I just make sure it's a 20 amp version. As long as it has AC/B+/AC, tractor doesn't care what it looks like or its size. I need to add a 12v fan though, my winch gets the regulatory pretty hot.
  • KennyP and TomLGT195 have said thanks
#26 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted May 06, 2015 - 09:39 AM
I didn't think it would make much difference, as long as the regulator was big enough. I am going to pull the pan off the engine and see if I can go to a smaller pan. Then I'll know what is going on.
#27 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 06, 2015 - 12:00 PM
HUH?
Just picking at ya!
#28 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted May 06, 2015 - 06:06 PM
Yep, what Tahoe said!
Ben W.
