Guess what caused this!
27 replies to this topic
#1 KennyP OFFLINE
  • 40,925 Thanks
  • 47,117 posts
Posted May 05, 2015 - 04:37 PM
Here's a pic of the regulator off an Allis 416S. The connector closest to the camera is way loose and the goodies under it look like they are fried. Let's see who can tell me what caused this issue.
  • tinbender7 said thank you
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted May 05, 2015 - 04:42 PM
Washing it too much.
  • KennyP and superaben have said thanks
#3 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted May 05, 2015 - 04:56 PM
If it wasnt an internal diode shorted... it was probably a wiring error, like possibly hooking the battery up backwards
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 05, 2015 - 05:00 PM
From the looks of all three blade connectors, I'll say it was high resistance causing excessive heat.
Mike
  • KennyP, chris m and LilysDad have said thanks
#5 DH1 ONLINE
DH1
    Electric Tractors
  • 5,424 Thanks
  • 5,617 posts
Posted May 05, 2015 - 05:10 PM
STELLA ???
#6 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted May 05, 2015 - 05:14 PM
Mice
  • alec said thank you
#7 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted May 05, 2015 - 05:52 PM
Bad luck
#8 GWest OFFLINE
GWest
  • 556 Thanks
  • 508 posts
Posted May 05, 2015 - 05:56 PM
Most of these regulators have one AC terminal tied to the 12V DC terminal internally. If you can figure out which one it is with an ohmmeter add the DC wire to that AC wire and it may still work.
Garry
#9 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 05, 2015 - 06:01 PM
Mounted near the battery & acid spit out on it?
#10 Freddie1911 OFFLINE
Freddie1911
  • 149 Thanks
  • 98 posts
Posted May 05, 2015 - 06:23 PM
  rectifier mounted loose, vibration.
#11 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted May 05, 2015 - 06:24 PM
Mike
+1
#12 KennyP OFFLINE
  • 40,925 Thanks
  • 47,117 posts
Posted May 05, 2015 - 06:37 PM
I'll let this go a bit longer before I reveal the correct answer!
#13 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted May 05, 2015 - 06:40 PM
All of the above !!
And I'm right !!!! :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana: :dancingbanana:
What did I win????
#14 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted May 05, 2015 - 06:44 PM
If I had posted this here in the Mechanical & Hydraulics forum that KennyP guy would have moved it to the eletrical forum  :rolling:
#15 KC9KAS OFFLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
I am also interested, as I had one that looked identical....and didn't work!
