Troy Bilt with auto choke
4 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,659 Thanks
  • 3,190 posts
Posted May 05, 2015 - 04:34 PM
I'm workingicon1.png on a troy bilt pushmower I cleaned the carb and the coil and it will start but dies instantly what else could it be ?
  • Thomasjent, laurarg3 and georgepf11 have said thanks
#2 Bolens 1000 ONLINE
  • 15,263 Thanks
  • 18,229 posts
Posted May 05, 2015 - 05:06 PM
Still sounds like a fuel issue , make sure your lines are clear
Will it keep running if you give it a shot of carb cleaner while running?
  • bbuckler said thank you
#3 bbuckler ONLINE
bbuckler
  • 3,659 Thanks
  • 3,190 posts
Posted May 05, 2015 - 05:08 PM
I will give it a try. the owner swears it the auto choke but the air vane system seems to be working right.
#4 Bolens 1000 ONLINE
  • 15,263 Thanks
  • 18,229 posts
Posted May 05, 2015 - 05:14 PM
Auto choke should be completely closed when engine is cold and the metallic components will heat it to fully open when running
#5 bbuckler ONLINE
bbuckler
  • 3,659 Thanks
  • 3,190 posts
Posted May 05, 2015 - 05:30 PM
Finished it just took one more carb cleaning I needed something to go right this week.
