Snow Blower belts
6 replies to this topic
#1 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 315 posts
Posted March 23, 2011 - 11:02 AM
My neighbor recently had the main drive pulley/shaft assembly changed out on his snow blower unit. He has it on his X324. So, $600.00 later and it will not keep a belt on it. He just called me and said it just threw it again. I am not too savvy on snow blowers, so am asking someone on here to perhaps offer some advice. He is 75 years old, and getting frustrated, as I would be, also. Thanks, guys for any help for us here.
#2 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted March 23, 2011 - 11:36 AM
Pulley alignment could be one cause. Another would be if a pulley doesn't spin as free as it should, primarily an idler pulley with bad bearings. Worn pulkeys could be another cause. I am ruling out bent shaft if he just had it replaced.
#3 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 315 posts
Posted March 23, 2011 - 11:45 AM
Now, i watched this thing run this morning. I noticed the idler pulley was kinda sloppy. Could this be an issue? I really would love to help this guy take care of this problem. He also put on a belt 1/2" shorter, and it still jumped.
#4 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted March 23, 2011 - 11:48 AM
He also needs to be sure he gets the belt from John Deere. I see more problems when owners try to go cheap on their belts. JD belts are made to strict specifications - and going aftermarket will cause problems.
#5 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted March 23, 2011 - 11:55 AM
The idler pulley being loose on the shaft could be part of the problem. Like TMO mentioned John Deere has different specs on a lot of their belts so normal off the shelf belts sometimes wont work.
The first thing is to make sure the belt is right. Then I would look in to the sloppy idler pulley.
#6 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted March 23, 2011 - 11:57 AM
Also make sure none of the pulley edges are bent, if the lip is bent out or in it can cause it to throw a belt.
#7 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted March 23, 2011 - 12:10 PM
:ditto:
Thats the same case for Bolens stuff. Normal off the shelf belts will disintegrate in a short time span.
