Kubota T1400 tires
3 replies to this topic
#1 Motofan81 OFFLINE
Motofan81
  • 41 Thanks
  • 34 posts
Posted May 05, 2015 - 08:00 AM
Need more traction, and Tractor Supply has a really good deal on these...
http://www.tractorsu...-8?cm_vc=-10005
Stock size tire is 8.5, these are 9.5.  I believe there is plenty of room to clear the frame but do you think I will have trouble getting a tire that much wider on the rim?
  • georgepf11 said thank you
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 05, 2015 - 10:44 AM
Those look really good. That one inch difference in width will make a big difference.
#3 OldBuzzard OFFLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted May 05, 2015 - 03:15 PM
As they are only 1" wider they should mount on your current rims with no problems.
  • Motofan81 said thank you
#4 Motofan81 OFFLINE
Motofan81
  • 41 Thanks
  • 34 posts
Posted May 15, 2015 - 07:34 AM
Stuck it in the yard again (riding the kid around in the trailer of all things, ha).  I just knew it was finally dry enough to cross, nope.
I think I am gonna need to stop procrastinating.
