Betcha never seen a walk behind tractor used this way!
23 replies to this topic
#16 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 06, 2015 - 02:46 AM
Agria Baby, Agriette, 1700, 1800 and Solos to throw out a few.
Edited by trowel, May 06, 2015 - 02:47 AM.
  • earthgrinder, Cvans, jpackard56 and 3 others have said thanks
#17 camdigger ONLINE
camdigger
  • 800 Thanks
  • 271 posts
Posted May 06, 2015 - 11:36 AM
Well, here is the secret to the high speed 2 wheel tractors....
I got some better pictures of the 2 wheeled tractor trailers in Turkey.  I labelled the trailer driveline bits.
The power unit has a rear PTO.  This PTO is connected to a 4 spd auto trans mission and rear end. See the attached.DSCN4317.JPG
By selection of ratios, they can get whatever speed they want (up to the HP limit). as posted before, I've seen them putting along at anywhere from a moderate walk to 35 mph on the local roads.  Pretty scary at night because the farmers use them to haul fuel out of the forestry area.  They work until it is too dark to chop wood, load the trailer portion until the last 5 sticks in a row fall off, and then jump on and head for home down the main road to town in the dark......
FWIW, the box is about 1 1/2 m wide x 2 m long or 4.5' x 6'
Edited by camdigger, May 06, 2015 - 11:42 AM.
  • KennyP, Cvans, pigsitter and 1 other said thanks
#18 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 06, 2015 - 04:14 PM
It proves that one can get things done without a tractor that costs half a million dollars?
Had a simplicity with a cart as a teenager. I can remember my great uncle delivering goats milk(for people with stomach problems) to the hospital in Albia up into the mid 50s with a cart pulled by a pair of goats. Guess you could call that cottage industry?
Edited by JD DANNELS, May 06, 2015 - 04:15 PM.
  • MH81, Cvans, holdenboy1960 and 1 other said thanks
#19 Tbrooks OFFLINE
Tbrooks
  • 508 Thanks
  • 326 posts
Posted May 06, 2015 - 09:19 PM
Here is one I like, source unknown.
I love that! I now have another project idea!
  • Cvans and camdigger have said thanks
#20 camdigger ONLINE
camdigger
  • 800 Thanks
  • 271 posts
Posted May 07, 2015 - 03:03 AM
Tbrooks
If you have the two ends, the power unit and the old car.  You just need some steel inventory and this doodad to connect them.  This is usually mounted to the trailer portion, and connected to a vertical clevis on the power unit.
Allows the unit to turn while keeping the two ends level and allows the two ends to walk over rocks, curbs, and the like.
#21 jd.rasentrac ONLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,265 posts
Posted May 07, 2015 - 05:06 AM
Here young guys and their Holder E6, harvesting potatoes
  • KennyP, trowel, jpackard56 and 2 others have said thanks
#22 Kilroy OFFLINE
Kilroy
  • 7 Thanks
  • 25 posts
Posted August 30, 2015 - 05:09 PM
What kind of power do you need though to run a cart with some stuff in it ? Hp
#23 camdigger ONLINE
camdigger
  • 800 Thanks
  • 271 posts
Posted January 16, 2016 - 02:42 PM
Some of these units range from 5 to 20 hp max.
#24 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 24, 2016 - 09:44 AM
there was 1 made that had a trailer with a diff in it to couple a drive shaft to the machine too to haul larger loads German made i think , and england made trailer sorts as well i think
  • DougT, KennyP and jpackard56 have said thanks
