Gard'n Mast'r Jr. steering wheel problem solved.
6 replies to this topic
#1 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted May 03, 2015 - 09:08 PM
As you can see, the original steering wheel on the tractor is toast. The steering wheel is 15" in diameter and has a tapered hub with a 1/4" key way cut and made by Sheller. I found a couple of NOS Sheller steering wheels that are the same, but have a tapered and splined hub. It took me 2 hours to make the key way cut with a 3/16" flat file and file out the splines with a coarse rat tail file. I kept test fitting the steering wheel on the steering shaft until it fit like the original. Another hurdle jumped for the restoration.
  • Alc, trowel, tinbender7 and 5 others have said thanks
#2 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted May 03, 2015 - 09:10 PM
Wow ! I though I was the only one that killed files making tapered holes, another step closer !
  • tinbender7, boyscout862 and classic have said thanks
#3 JBRamsey OFFLINE
JBRamsey
  • 1,593 Thanks
  • 886 posts
Posted May 03, 2015 - 09:39 PM
Nice work. Patience pays off, but why not use a tapered ream on the splines? I'm just curious in case I ever need to do the same.
  • tinbender7 and classic have said thanks
#4 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted May 03, 2015 - 09:48 PM
Thanks, but I only have about 50 old files laying around and no tapered reamer. I did consider buying one, but I would most likely never use it again. It does take a lot of patients restoring these old machines, breaking down every component, inspecting, cleaning, repairing, and locating parts is a chore. Then comes paint, reassembly, and more paint. It's a fun hobby except for the sand blasting part.
Edited by classic, May 03, 2015 - 09:50 PM.
  • tinbender7 said thank you
#5 HANKG OFFLINE
HANKG
  • 6,610 Thanks
  • 3,534 posts
Posted May 04, 2015 - 06:02 AM
How did you find the extra wheels? I would think that an impossible task and how did you cut the keyway the file in the photo looks to big. Did you choose a spot between the splines to cut the keyway first ?
Edited by HANKG, May 04, 2015 - 06:07 AM.
  • classic said thank you
#6 classic ONLINE
classic
  • 5,690 Thanks
  • 2,385 posts
Posted May 04, 2015 - 07:15 AM
Hank, these steering wheels were used for cars, trucks, boats, old golf carts, etc., so they do turn up for sale at times. The seller just happened to come across some NOS ones and had them listed for sale, so I bought a couple. The other one is for my '56 Power King tractor which uses the same steering wheel. The key way cut is actually 3/16" and my file is 9/64" thick, I just measured them. I used the edge of the file to make the cut.I used the lines of the splines as a visual guide as I filed, but it was basically done free hand and was tedious.
Since this tractor was built using car parts, I've been learning a lot about 30's Chryslers, De Sotos, Dodges, Crosley cars, and 40's Jeeps. It's been time consuming figuring out exactly what vehicles these parts came from in order to find replacement parts. I had to buy a replacement steering column tube for a Willys MB that I will have to shorten and weld the throttle bracket to. I'm documenting the restoration here on the forum in case someone else needs the information to restore or repair their Gard'n Mast'r Jr. tractor. There really isn't much detailed info out there regarding these tractors, so this info I'm passing along should be useful.
Edited by classic, May 04, 2015 - 07:47 AM.
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted May 04, 2015 - 07:47 AM
Nice job! :worship:
