John deere 212
fuel filter plug coil seat switch ground
6 replies to this topic
#1 codyteet212 OFFLINE
codyteet212
  • 4 Thanks
  • 7 posts
Posted May 03, 2015 - 04:41 PM
Hello my name is cody and im new here and in need of some help!! I just bought my first john deere 212 and I came with out a deck! So bought a 46'' deck for it rebuilt the deck so I was ready for the cutting season! So I get the deck on and it cuts fine but then starts throwing the belt now ive been told by 2 different dealers that I needed these belts M47765,M47766 I bought the m47765 do I need the 66 because my tensioner is adjusted to the fullest and its still spitting the belt!? My second prob is that since I put the deck on the tractor is acting likeits loosing fuel pressure runs and almost dies and I push the clutch in and it picks back up and runs fine for about 5-10mins and does it again! If its just sitting still it will run all day wide open or at a idle I have no idea whats going on could it be the fuel pump or could it be the filter in the tank the tank is clean nothing floating in it! Please help
  • propane1 and larisaPn have said thanks
#2 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted May 03, 2015 - 06:24 PM
Hi Cody. Welcome to the site. Lots of help full people on here. Maybe check in the manuals section of the site, that may help your belt trouble. Have to make sure all the pulleys and idlers are lined up good.
You may have a bad gas tank cap for the engine trouble. The cap has to allow air into the gas tank, so it will allow gas out to the carb. Not enough air coming into the tank will starve the carb. Depending on how bad the cap is. Just some suggestions, Noel
#3 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted May 03, 2015 - 07:42 PM
Welcome!
What is the serial number on the deck and the tractor?  Both of those can make a difference when it comes to belts.  Get that info handy and I can point you in the right direction.
:wewantpics:
Travis
  • Cat385B said thank you
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted May 03, 2015 - 08:04 PM
Run with the fuel cap loose and see if the problem remains. If it does, remove the points cover and check the condition and gap of it. It should be set to .020".
As Travis pointed out, manufacture date in the deck makes a difference. Serial # and a picture or two will help us help you.
#5 codyteet212 OFFLINE
codyteet212
  • 4 Thanks
  • 7 posts
Posted May 04, 2015 - 02:55 PM
thanks guys I will get these for you asap good thing its raining all week so I can get this thing fixed the fuel cap is bad the glass or the plastic that goes over the gauge is gone so maybe this is the problem I will buy a cap at deere dealer and see if that is the problem thanks again!!!
#6 codyteet212 OFFLINE
codyteet212
  • 4 Thanks
  • 7 posts
Posted May 04, 2015 - 03:11 PM
H047D 301078M is the deck number tractor serial number M00212X288324
#7 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted May 06, 2015 - 09:11 AM
Posted in the new thread... I hope mods can combine the two for future reference.
Also tagged with one or more of these keywords: fuel, filter, plug, coil, seat switch, ground
