Tried again, Broke again
12 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted May 03, 2015 - 09:13 AM
2 yrs ago I went to French Creek plowday with my electric tractor, ET2, to see if it could pull the plow like the gas tractors can. I was all set up, made a pass down the field and on the return leg the transmission broke. Lost all drive in all gears. :mad2:  :wallbanging: Plowed less than 5 minutes with it.
This yr I tried again, made 6 or 7 rounds, then the shifter slipped out of gear and the trany was now stuck in 1st gear, creeper gear. I was using 2nd gear for plowing. Tractor still moves, pulls the plow, but at a snails pace.  :mad2:  :wallbanging: . Plowed more than 1 hr, almost 2hr with it.
Made 2 more rounds then drove it up on the truck to come home.
ET2 CAN do it. :dancingbanana:  :dancingbanana:  :dancingbanana:
So I guess I'll have to come back next yr and try not to break it again.
All in all it was a great day, weather, people, food, had a fun day. :thumbs:
  • olcowhand, daytime dave, DougT and 11 others have said thanks
#2 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted May 03, 2015 - 09:32 AM
Cool tractor, then NOT a GE brand, but homemade from a Massey??  Where'd you get that GTTalk decal? Have those made, or sell here?  I might need some for a tractor of mine. Maybe those motors just won't hold up to ground work that hard, more for lighter mowing and such?  Would think would need Heavy bearings in the items to hold up to plowing??
  • DH1 and wvbuzzmaster have said thanks
#3 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted May 03, 2015 - 09:44 AM
Good looking tractor!  Too bad the transmisssion has turned into your weak link. Do you think it is just this paticular transmission?
  • DH1 said thank you
#4 KennyP ONLINE
  • 40,983 Thanks
  • 47,148 posts
Posted May 03, 2015 - 09:54 AM
I'm glad you got to plow with it more this time. I'm sure you'll get the tranny issue figured out and be plowing with the best of them, Doug.
#5 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted May 03, 2015 - 11:34 AM
Great to see you representing the electric tractors Doug.  I hope the kinks get worked out for next year.
  • DH1 and KennyP have said thanks
#6 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 03, 2015 - 11:39 AM
You should have all the kinks out of it by my plow day then Doug!
#7 toppop52 ONLINE
toppop52
  • 5,546 Thanks
  • 4,907 posts
Posted May 03, 2015 - 11:40 AM
Those electric motors make all their torque at zero rpm, so you need a good tranny and maybe a way to soft engage the clutch, or just go hydro.
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted May 03, 2015 - 11:45 AM
Yes this is the Electric Massey I converted 4yrs ago, I got the Decals from "olcowhand".
I think it's just bad luck or Murrphys law working against me.
The Detent is not very strong on the shifter, weak or broken spring I figure. Still to fix it I have to remove and split the trany.
  • MH81, Alc, KennyP and 1 other said thanks
#9 propane1 ONLINE
propane1
  • 9,474 Thanks
  • 4,408 posts
Posted May 03, 2015 - 02:15 PM
Where is French Creek plow day at?? Noel
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted May 03, 2015 - 02:20 PM
Doug, I'm sorry you had to go thru this a second time. At least the ET2 can pull the plow and you seemed to be having a good time. You were keeping up with the Beaver, so that says something.
If I were a betting man, I'd say you're dealing with detent and rails more than actual breakage.
At least I hope that's all it is.
#11 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted May 03, 2015 - 04:02 PM
Attached File  15 PLOW DAY POSTER 1f.pdf   2.23MB   28 downloads
  • MH81 and propane1 have said thanks
#12 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
I think your right.
#13 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted May 03, 2015 - 09:51 PM
Nice tractor!
