Onan Engine Stalls when tractor bounces
16 replies to this topic
#1 MountainBuzzMan OFFLINE
MountainBuzzMan
  • 75 Thanks
  • 35 posts
Posted May 02, 2015 - 09:55 PM
Hi Guys,
I was mowing today and I was going down hill and hit a dirt mount that made the tractor bounce 2-3 times.  Each bounce would stall the engine for a bit.  Everything was fine within a second or two.
Is this normal?  I picture the fuel sloshing around in the carburetor bowl.
It bounced later, but only one little bounce and there was a hesitation that time as well.
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted May 02, 2015 - 10:17 PM
Is your battery secure? Could be bouncing up and shorting out on stuff... It's a thought. Otherwise you could have a wiring issue somewhere...
Edited by wvbuzzmaster, May 02, 2015 - 10:18 PM.
  • MountainBuzzMan said thank you
#3 Hobal OFFLINE
Hobal
  • 19 Thanks
  • 41 posts
Posted May 02, 2015 - 10:22 PM
I would venture a guess that you have a low oil shutoff sensor that kills the engine if the crankoil level is too low. Or a ground short thats killing the spark. Maybe look for anything that maybe rattling, or a weak worn spot in the positive run of the wiring? My guess is crankcase oil level. Good luck sir.
#4 MountainBuzzMan OFFLINE
MountainBuzzMan
  • 75 Thanks
  • 35 posts
Posted May 02, 2015 - 10:50 PM
I checked the oil before and after I mowed and it was full.
So you don't think it is the carb?  I will double check the battery to make sure it is secure.
#5 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted May 03, 2015 - 04:51 AM
Carbs shouldn't be that affected by a bump. I have driven all kinds of carbed tractors over bumps and never had an issue. I would also say look for wiring shorts as my first guess.
#6 MH81 OFFLINE
Posted May 03, 2015 - 06:01 AM
If there is enough condensation in the bowl of the carb, it could be causing issues when sloshing.
I'd check for a loose wire and run a little dry gas thru it to see if anything makes a difference.
#7 olcowhand ONLINE
  • 41,202 Thanks
  • 31,432 posts
Posted May 03, 2015 - 06:27 AM
More than likely an electrical issue, as most fuel issues aren't that short in duration.
  • MH81 and MountainBuzzMan have said thanks
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 03, 2015 - 06:28 AM
I'd give all the electrical system a good once over. You could have a short or a bad connection somewhere which is cutting off the spark.
#9 olcowhand ONLINE
  • 41,202 Thanks
  • 31,432 posts
Posted May 03, 2015 - 06:36 AM
Electrical problems are tricky to find sometimes.  I had a Massey 85 lawn tractor that misfired ONLY during left turns.  I looked over the wiring well and didn't find anything.  Then I went into the carb a few times, again finding nothing.  Finally I pulled the engine cover and discovered a loose mag coil.  Tightened it & problem gone.  You don't have magneto of course, but anything loose can cause your problem.
#10 KennyP ONLINE
  • 38,399 Thanks
  • 45,943 posts
Posted May 03, 2015 - 06:42 AM
Lots of good suggestions here. It might not hurt to check float level/possibility of a small amount of water in there. I know mine are real temperamental of the float level. Which Onan is this?
#11 MountainBuzzMan OFFLINE
MountainBuzzMan
  • 75 Thanks
  • 35 posts
Posted May 03, 2015 - 08:23 AM
Thanks for all the suggestions.  I will look for wiring issues. If it is subtle now, it will only get worse.
The Engine is a T260G 24 horse.
#12 Shotgun429 OFFLINE
Shotgun429
  • 5 Thanks
  • 4 posts
Posted May 03, 2015 - 11:05 AM
Seat sensor,  This normal on bounces.
  • KennyP, LilysDad and MountainBuzzMan have said thanks
#13 MountainBuzzMan OFFLINE
MountainBuzzMan
  • 75 Thanks
  • 35 posts
Posted May 03, 2015 - 11:11 AM
I will check it.  But I think it is to old for that.  I don't think there is a sensor as it is designed to be quickly removed to change position. (Leg Room)
#14 KennyP ONLINE
  • 38,399 Thanks
  • 45,943 posts
Posted May 03, 2015 - 01:31 PM
Okay, we are talking about your FF24 tractor here, right? No seat switch there I know off. I'd have to look at an electric diagram to see what safety's these have.
#15 KennyP ONLINE
  • 38,399 Thanks
  • 45,943 posts
Posted May 03, 2015 - 01:45 PM
Here's some pics so the rest of you folks can see how these are wired.
