Tiger tractor 5ph B&S
7 replies to this topic
#1 tom tractor OFFLINE
tom tractor
  • 236 Thanks
  • 225 posts
Posted May 02, 2015 - 05:19 PM
Can anyone tell from the photos what year this tiger tractor is? How rare?
  • Alc, hamman, boyscout862 and 2 others have said thanks
#2 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted May 02, 2015 - 05:46 PM
If you can get the engine numbers we can probably get a good idea when it was made
According to the writing on the hood its VERY rare!!! :D
  • Alc and superaben have said thanks
#3 tom tractor OFFLINE
tom tractor
  • 236 Thanks
  • 225 posts
Posted May 02, 2015 - 06:31 PM
No engine number found.  No serial number on tractor.
#4 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 02, 2015 - 06:43 PM
Ok, on the engine, the tin cover that wraps around the cooling fins will have the tag with the model, serial and type numbers. The cover is facing the front of the tractor.
  • superaben said thank you
#5 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,913 posts
Posted May 02, 2015 - 11:24 PM
One of most Complete ones I have seen for sale. I have a book on those from a collector back when they had a Yahoo group for them. Not sure if group still around or not. Not much diff in any tractor models till near end of the run they had couple improved models. As said, one with all the belt covers and hood that nice and attachments is good deal if you like the brand. Not sure what happened to book, have to look some. Wonder if serials just stamped in frames like Speedex did and get painted or dirty'd over?
#6 karel OFFLINE
karel
  • 2,073 Thanks
  • 1,386 posts
Posted May 03, 2015 - 04:41 AM
that was at zagray's
#7 tom tractor OFFLINE
tom tractor
  • 236 Thanks
  • 225 posts
Posted May 03, 2015 - 05:10 AM
Yes.  What a great show.
#8 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted May 03, 2015 - 07:53 AM
Don't know if this helps any: http://gardentractor...actor-brochure/
The model in the brochure used a B&S Model 14 engine.  ...This brochure was from the early 1950's.
As Trowel said, engine numbers should be stamped into plate covering cooling fins (attached by a cylinder head bolt).  ....Then it's easy to date the engine/tractor.
  • tom tractor said thank you
