hydro from B112 into large frame ?
5 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 02, 2015 - 01:02 PM
Will hydro lift from a B112 fit into a 3415 or 7016 or 712 or 7112 ?
#2 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted May 02, 2015 - 04:51 PM
Pretty sure it won't dashes are completely different
  • alec said thank you
#3 Talntedmrgreen OFFLINE
  • 3,280 Thanks
  • 2,313 posts
Posted May 02, 2015 - 10:19 PM
A B112 is a large frame, but there is no compatibility between FDTs and RBTs when it comes to power lifts (your early RBTs would normally have had elwctric lift as an option).
#4 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 02, 2015 - 11:19 PM
but they do make a hydro lift for them right ? how hard are they to find and how much should I pay ?
Edited by alec, May 02, 2015 - 11:19 PM.
#5 Talntedmrgreen OFFLINE
  • 3,280 Thanks
  • 2,313 posts
Posted May 04, 2015 - 06:45 AM
They offered hydro lift for 7100/900 series tractors, but not for the earlier RBT models.  I would have to think a 7100 style hydrolit could be fitted to a 7000 series, but am not sure what obstacles you would face.  The Sunstrand pump would need the valves shimmed, I believe, as they are not setup to support the additional load that a lift would present.  I think early 7100s (which also had electric lift available) required this as part of a dealer hydrolift install.  I have seen components cheap...probably total $150, and more commonly, sold separately for up to $150 per major component.  Electric lift would be a simply install, but I personally do not care for the speed or ease of use of that style.  The biggest benefit, however, is that you can operate the lift without starting the tractor.
http://www.ebay.com/...=item33a207f1c3
#6 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 04, 2015 - 09:16 AM
I agree 100% about the electric lifts.
