roller atachment
10 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 02, 2015 - 07:11 AM
here is some thing different for me to find
it is an old style roller & seat attachment for a walk behind of sorts
  • hamman, trowel, tinbender7 and 1 other said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 02, 2015 - 07:30 AM
That would need quite a balancing act!
  • tinbender7 and holdenboy1960 have said thanks
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted May 02, 2015 - 07:34 AM
I'd like to see that in action. I can't figure out how it wold mount from the view in that picture.
  • hamman, trowel, tinbender7 and 2 others have said thanks
#4 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 02, 2015 - 07:57 AM
lol  that is the rear part, it is the seat section for behind the machine itself. the seat part there has a little hitch pole in front of it , bit like articulated steer . over here in aussie we had some walk behind slasher mowers with a rear hitch dicki seat attachment for them. the councils used to use them yrs ago to mow the public parks & such witch hitched with a pin only
  • Alc, hamman, trowel and 2 others have said thanks
#5 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted May 02, 2015 - 08:04 AM
Wish I had pictures of me riding one like that from back in the 60s. My dad and uncle used to care take two large cemeteries. They would dig graves and mow and trim the grass there. They had Snapping Turtle walk behind mowers with rollers that you would stand or sit  on behind the mower. I really liked riding because those seat were more comfortable than standing on platform or steps on the roller. thanks for sharing.        Roger
  • Alc, trowel, tinbender7 and 2 others have said thanks
#6 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 02, 2015 - 08:47 AM
i  might dig my walk behind slasher mower out & alter the hitch for that attachment , mine is the same as this 1 , but mine has all the cutter covers IMG_1329_zps3088d598.jpg
Edited by holdenboy1960, May 02, 2015 - 08:49 AM.
  • hamman, trowel and chieffan have said thanks
#7 chieffan OFFLINE
  • 10,135 Thanks
  • 6,632 posts
Posted May 02, 2015 - 12:52 PM
A little off topic but not really. I built a roller using the top roller from an old AC round hay baler. Those were called cigar rollers among other names. The top roller is about 38" long and 16" diameter and has a large round shaft running through it and protruding out about 3" on both ends. Easy to used a heavy U bolt and angle iron for the hook up. Drilled a hole in the end near the edge and threaded it to fit a 1/4" plug. Add what ever amount of water you need for the weight and your set to go. Keep the U bolt greased and little to no friction as you have round bolt riding on round shaft. Makes a nice cheep smooth lawn or ground roller and will last a lot longer than those plastic one the stores sell for $100 or more. If you fill it with water, don't plan to move it much by hand. That sucker is heavy !
  • hamman, trowel and holdenboy1960 have said thanks
#8 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 02, 2015 - 06:47 PM
Nice slasher !
#9 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 09, 2015 - 04:20 AM
P9220015.JPG how Machines deteriorate when there left out in the weather for some 6 odd yrs ' i was so disappointed when i got my walk behind slasher mower out from up back , most of the out paint has lifted off the machine & what never has faded dramatically ............in other words it is a mess, 1 good part was the carbie was still spotless & the spark was good enough to weld with
#10 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted May 09, 2015 - 04:47 AM
P9190005.JPG made an attachment tow bar to show ya'll what i meant as a dicki seat roller attachment , i have coupled it to the rover slasher
  • KennyP and trowel have said thanks
#11 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted May 09, 2015 - 04:56 AM
Nice !! roll the ground and strip the grass at the same time.
