Spring routine?
7 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted May 01, 2015 - 09:23 PM
Tonight as i did final prep on my John Deere before i start mowing i started wondering what everyone else does. Myself i clean the deck an grease it an, the tractor get waxed tire shine an back to black to revive it. So what do you guys do??uploadfromtaptalk1430533356381.jpg uploadfromtaptalk1430533374840.jpg
  • tinbender7, Traill95 and boyscout862 have said thanks
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted May 01, 2015 - 10:01 PM
Same, take the tractor off the ceiling and put it on the floor.
  • limebuzz, JDBrian, trowel and 3 others have said thanks
#3 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted May 01, 2015 - 10:02 PM
Also looks like you hang it upside down from ceiling! Best way to clean deck and change blades?  :smilewink:
  • tinbender7, Cat385B, oldedeeres and 1 other said thanks
#4 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted May 01, 2015 - 10:04 PM
Clean the deck, sharpen blades, check belts and pulleys, new spark plug, change oil, clean/change filters. Carb usually gets cleaned and adjusted every few years.
  • tinbender7 said thank you
#5 propane1 ONLINE
propane1
  • 8,482 Thanks
  • 4,041 posts
Posted May 01, 2015 - 10:43 PM
I do all the things before I put them away for winter. Then maybe the odd fix up
In the spring. Does not always work that way, but that's what I try and do , so in the spring , put the battery in , start her up and go cuttin. Noel
  • tinbender7 and DennyIN have said thanks
#6 oldedeeres OFFLINE
oldedeeres
  • 9,178 Thanks
  • 4,644 posts
Posted May 02, 2015 - 12:27 AM
Olde dog, new trick, as I guess I've said before. This was always Olde Deere #1's pet job. Thanks for giving me an outline to follow you guys.
  • propane1 said thank you
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted May 02, 2015 - 06:19 AM
I see i still cant take pictures right with my phone lol. This year ill be changing the blades after ive mowed twice.
#8 TAHOE OFFLINE
TAHOE
  • 7,821 Thanks
  • 5,614 posts
Posted May 02, 2015 - 07:41 PM
Put gas in, hope it starts   :bigrofl:
