Need Help with Onan Engine
onan john deere
1 reply to this topic
#1 Firepuppy OFFLINE
Firepuppy
  • 5 Thanks
  • 3 posts
Posted May 01, 2015 - 04:20 PM
I have a John deere 316 with a Onan B43e engine the motor blew up and broke connecting rod i bought another block and am going to transfer the parts to the other block what i found was the original connecting rod is a 170-3439 and it says k2 on the inside of the rod and 3 on bearing cap the replacement rod i bought is a 170-3439 but it says k3 in the inside of rod and a 4 on bearing cap does this make a difference even tho the parts number is the same can i use the k3 in the same motor with a k2 connecting rod
  • rustyoldjunk, superaben and larisaPn have said thanks
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 01, 2015 - 04:25 PM
You're fine. The rod number is what matters.
  • rustyoldjunk, Firepuppy and superaben have said thanks
Also tagged with one or more of these keywords: onan, john deere
