HT20 "Yard Rat" .. well it was going to be.. Really!
18 replies to this topic
#1 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5113 Thanks
  • 1215 posts
Posted May 01, 2015 - 03:29 PM
Picked this up last fall, it's been setting .. waiting ..wondering .. So 'cause I'm totally bored and with nothing to do (A HAHAHA, um right) I thought I'd see what was ailing it. For starters bad starter , rebuilt one replaced it, next starter solenoid didn't like I yanked its ol' buddy starter #1 , so it went on strike , being a good Union guy I tried to negotiate in good faith, but in the end negotiations broke down (as did the solenoid) and I unceremoniously replaced it with a new one (USA made!). Next all the usual suspects were found to be 'lacking a good , solid effort ' so they got canned ( cripe now I sound like management, I'll make amends Hank , promise). Plugs, plug wires, points, fuel lines, condenser , coil, fuel filter , etc. etc. replaced.
Noticed (and felt)a bad vibration , a lot of stress cracks as well . Universals on the driveshaft had seen enough. Good used d-shaft volunteered and was installed. Gave the old boy a compression test , and he got a (IMO) B . Some pretty funky looking carpet took the foot pads place I'm guessing years ago and left their mark, 'course being bored and lacking projects I broke out the glue gun & melted some metal together burning some consumables into the mix as well, put the pan in the blast cabinet and hit all the pitted metal, a feather of fiberglass and of course primer and paint and the old pan will be as it should. And.. well.. I guess it means the whole darn thing is going to get refurbed.
Edited by WrenchinOnIt, May 01, 2015 - 03:49 PM.
  • Bolens 1000, OldBuzzard, LPBolens and 17 others have said thanks
#2 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted May 01, 2015 - 04:42 PM
Looks like it has alot of potential!
Looking good so far :thumbs:
  • blackjackjakexxix, tinbender7, WrenchinOnIt and 1 other said thanks
#3 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted May 01, 2015 - 05:41 PM
Looks like a good Union Built! job to me there wrenchinOnit
  • blackjackjakexxix and WrenchinOnIt have said thanks
#4 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted May 02, 2015 - 02:51 AM
Nice revival! Will be following. :)
  • 15135 Thanks
  • 15577 posts
Posted May 02, 2015 - 05:23 AM
Looking good so far, waiting to see how you finish it up. Good job !! :thumbs:
#6 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted May 02, 2015 - 05:01 PM
Looks great! Will be following your progress.
#7 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5113 Thanks
  • 1215 posts
Posted May 12, 2015 - 04:51 PM
Bit of an update, discovered this (1st pic) which led to this (2nd pic ) went 4 for 4 got 'em all ! Next pics of repair work and couple of the fender pan ( apologize for poor quality of pic on last 2)
  • Bolens 1000, LPBolens, blackjackjakexxix and 3 others have said thanks
#8 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted May 12, 2015 - 05:21 PM
Nice Work!
I really like the repairs you made to that broken housing, I wish more people would fix these OEM engines instead of swap them!
Awesome work!!! :thumbs:
  • LPBolens, WrenchinOnIt and AA Hayes have said thanks
#9 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5113 Thanks
  • 1215 posts
Posted May 17, 2015 - 07:48 PM
This weekends progress, couldn't see painting the frame engine in, firewall bent and stress cracked so I pulled the engine, pushed it outside to degrease and pressure wash it , also discovered the bull gear is bad 😕 ( yay )
Tired of cleaning these engines (takes about half case or more of brake cleaner) and the crap running all over, so I made an engine cleaning stand today , also tired of bending over wrenchin on 'em so I made it height specific for user , that'd be me. Last pic couple pics I knocked down the paint on one of my 23's hood reshot it and stickered it ( had to sneak it in here )
  • Bolens 1000, MailmAn, Sawdust and 2 others have said thanks
#10 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted May 17, 2015 - 07:56 PM
Looking great!
The least favorite thing for me doing a resto is removing the decades of filth and grease on the engines!!!!
  • WrenchinOnIt and MailmAn have said thanks
#11 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted May 17, 2015 - 08:00 PM
Looks like fun to me!
  • WrenchinOnIt said thank you
#12 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted May 17, 2015 - 08:08 PM
This weekends progress, couldn't see painting the frame engine in, firewall bent and stress cracked so I pulled the engine, pushed it outside to degrease and pressure wash it , also discovered the bull gear is bad ( yay )
Is that all back together again or is the battery/gas tank plate still off?  I can almost see the area I am having trouble figuring out.  Might you have the time, and inclination, to take a couple close up pics of that PTO linkage assembly for me?  Top and bottom would be great if still visible.  I have one on my HT23 that isn't hooked up due to a cracked bolster and is missing a couple parts.  All set until it reaches the axle support.  That's where he took it apart.  Parts guide doesn't show how it is supposed to look inside the front area.
Edited by Paulgo, May 18, 2015 - 07:03 AM.
#13 chieffan ONLINE
  • 16657 Thanks
  • 9106 posts
Posted May 18, 2015 - 07:08 AM
Rather than buy that expensive carb cleaner, go to dollar Store (or what ever you have close) and get a case of oven cleaner.  Lot cheaper and works just as good.  Spray it on, let it soak in, wash it off.  May have to re soak a few think spots but that is normal.  It takes paint and all if left on to long.
  • WrenchinOnIt and Sawdust have said thanks
#14 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5113 Thanks
  • 1215 posts
Posted May 21, 2016 - 06:47 PM
Well a year later and the engine is done, hope to finish painting the tins this week.
  • Bolens 1000, LPBolens, MailmAn and 3 others have said thanks
#15 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted May 21, 2016 - 06:57 PM
Very nice,good job
