Troy Bilt GTX 20 Eaton 11 Pump Diag and Replacement
18 replies to this topic
#16 bwswede OFFLINE
bwswede
  • 3 Thanks
  • 3 posts
Posted April 05, 2011 - 03:50 PM
Have you tried running the tractor at full throttle when you move it? At low rpm's the pump may not be putting out its full pressure.
The second hydraulic lever is for the set of quick connects at the front of the tractor.
There should be a drain plug at the bottom of the transmission. It may be easier to use a hand suction pump to pull a little bit of fluid out. Do this before running the tractor at high rpms.
Nice tractor by the way.
Good luck,
BWSwede
  • Nascar3244888 said thank you
#17 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted April 05, 2011 - 04:01 PM
going to be uploading vids from earlier when i was beginning this swap of trans/hydros the next one will be of me removing all the stuff in the way of me seeing the trans and removing parts that would give me access to remove the trans itself.
#18 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted April 05, 2011 - 05:39 PM
scratch that, i forgot that it was on my old computer which crashed and burned last week....Going to do be uploading a vid of the finished product later today...
#19 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted April 06, 2011 - 03:53 AM
Heres the video
