314 Clutch Idler Pulley Question
7 replies to this topic
#1 DougN OFFLINE
DougN
  • 10 Thanks
  • 35 posts
Posted April 30, 2015 - 08:46 AM
I just picked up a 314 and it seems pretty good mechanically except for the clutch. When I move the idler pulley it has a lot of play in it side to side in particular. Doesn't disengage really well to put the tractor in gear and I have a lot of belt clatter.
Does it sound like something needs replacing or adjusting? The pulley itself seems fine its the linkages where the play is.
Thanks,
Doug
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 9,033 Thanks
  • 4,998 posts
Posted April 30, 2015 - 09:50 AM
The PTO clutch right?  314's are beasts!
The PTO bearing is either AN111537 if it's a Warner or if it's an Ogura
Look your parts up in this WEBSITE
Edited by WNYTractorTinkerer, April 30, 2015 - 09:50 AM.
#3 DougN OFFLINE
DougN
  • 10 Thanks
  • 35 posts
Posted April 30, 2015 - 11:46 AM
Its an Allis Chalmers 314. Sorry, I should have said that. Its the drive clutch assembly that has a lot of play in it. The belt there makes a lot of clattering noise too especially when the clutch pedal is in.
#4 skunkhome OFFLINE
skunkhome
  • 322 Thanks
  • 455 posts
Posted April 30, 2015 - 09:44 PM
Get the manual and go through the brake and clutch adjustment from start to finish. I take it that you have a Vari-drive. If so a lot of your issues can be coming from the pulley halves, but adjusting the brake and clutch should go a long way to eliminating the issue.
  • DougN said thank you
#5 DougN OFFLINE
DougN
  • 10 Thanks
  • 35 posts
Posted May 01, 2015 - 11:22 AM
Thanks Phil. I will take a look at the things you mention. The machine seems to be in pretty good shape mechanically other than that.
#6 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 9,033 Thanks
  • 4,998 posts
Posted May 01, 2015 - 01:03 PM
OOP's  (hides head)   :hitting_self_roller:
#7 skunkhome OFFLINE
skunkhome
  • 322 Thanks
  • 455 posts
Posted May 01, 2015 - 06:40 PM
BTW, making adjustments on the 300 and 400 series can be fun with that stationary fender pan in the way.
#8 DougN OFFLINE
DougN
  • 10 Thanks
  • 35 posts
Posted May 01, 2015 - 08:42 PM
Yeah it looks like at least it would have be raised up and a back wheel taken off to get access to it. I have worked on machines, autos, etc. but this is my first garden tractor. So some models of the Allis Chalmers have removable fenders? That would be a really good design thing.
