7016 solenoid help
7 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 30, 2015 - 02:16 AM
so the solenoid my be bad . I know you guys know the right way to jump one to see if the engine works before I blow fifty bucks on one .the wierd part is that it is located under the dash and it does not have the big starter generator that most do . the model number is 326437 ...type 0252-01.if I got one at the parts house what would I need to know ? . all your help has not been wasted . I am saving the posts and have gotten several tractors running :thumbs:  thank you so much  I am learning a ton and enjoying it immensely !
#2 KennyP ONLINE
  • 41,448 Thanks
  • 47,381 posts
Posted April 30, 2015 - 05:56 AM
Jump across the 2 posts with the big wires on them. You could also have a bad connection at a safety switch.
  • alec said thank you
#3 chieffan OFFLINE
  • 11,761 Thanks
  • 7,276 posts
Posted April 30, 2015 - 06:54 AM
Can you hear a clicking from that solenoid?  If not you have other issues like KennyP mentioned.  If you can hear that clicking  (should click when you turn the key to the start position),  the solenoid can be repaired if it is riveted together.  Let me know if you need the details.
Edited by chieffan, April 30, 2015 - 07:46 AM.
#4 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 30, 2015 - 10:00 PM
Also make sure you are getting the telegraph signal to the small terminal on the solenoid when you turn the key.
If you turn the key and the solenoid clicks it is getting the signal.
If it does not click it could be that the solenoid is bad or that it is not getting signal. Try using a jumper wire 14-12 ga from the positive terminal of battery to the small terminal on the solenoid.
If it clicks and the starter turns then you have a break in the safety circuit, a bad starter switch, or a blown main breaker.
If it does not click than solenoid is dead or not properly grounded.
If it clicks but the starter doesn't turn then the solenoid or starter is bad.
If you then take a heavy cable like a jumper cable, connect it to the positive terminal of the battery then to the lead going from the solenoid to the starter. The starter should crank. If it does not, the starter is bad and if it does crank, the solenoid is bad.
On all tests make sure the connections on the solenoid are clean and tight.
Edited by skunkhome, April 30, 2015 - 10:13 PM.
#5 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 30, 2015 - 10:37 PM
thank you again phil ! this would not be near as fun without your wisdom and guidance ! its nice to be able to understand what is being said . ( they need another thank you cartoon guy I dont really want to blow you kisses ... lol . even though you deserve it .
  • skunkhome said thank you
#6 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 30, 2015 - 10:54 PM
Thanks, but My wife might object...lol
Edited by skunkhome, April 30, 2015 - 10:55 PM.
#7 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 30, 2015 - 10:59 PM
this is a tractor forum ?!? why would that even be an option ? they must be messin with us
:shoot2: :flamethrower:
Edited by alec, April 30, 2015 - 10:59 PM.
#8 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted May 02, 2015 - 07:12 PM
I am letting you know that I need the details .  thank you !!  :thumbs:
