Some Bad Luck
13 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 29, 2015 - 05:34 PM
I got a rebuilt kit from ebay and the new main jet broke inside the carb.  :wallbanging:
will this aftermarket carb work on my ss15 ?
http://www.ebay.com/...=item4636ec38bb
#2 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,883 Thanks
  • 5,960 posts
Posted April 29, 2015 - 05:58 PM
Guys may need to know more about your tractor to help.
I didn't know they out Briggs and the sears tractors..
#3 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 29, 2015 - 06:00 PM
Its a 1972 SS15 has a briggs and stratton 325431-0139-01
#4 EricFromPa OFFLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted April 29, 2015 - 08:18 PM
Will work on the following Model Numbers:
170401, 170402, 170403, 170407, 170412, 170417, 170431, 170432, 170435, 170437, 170452,  170457, 190401, 190402, 190403, 190406, 190407, 190412, 190415, 190416, 190417, 190431, 190432, 190435, 190436, 190437, 190451, 190452, 190457, 190492, 190493, 190496, 190497, 195412, 195422,  195423, 195431, 195432, 195433, 195435, 195436, 195437, 195451, 195452, 195457, 220416, 220431, 220432,  220435, 220437, 221431, 221432, 221433, 221435, 221436, 221437, 221452, 221457, 222412, 222413, 222416,  222417, 222496, 243431, 243432, 243434, 243436, 243437, 243451, 243452, 243457, 251411, 251412, 251415,  251416, 251417, 252411, 252412, 252413, 252415, 252416, 252417, 254412, 254415, 254416, 254417,  254421, 254422, 254425, 254426, 254427, 300421, 300424, 301431, 301434, 302431, 302432,  302434, 302437, 325431, 325434, 325435, 325437, 326431, 326432,326434, 326435, 326436, 326437, 327431, 32K437
Looks the same as an OEM briggs carb.Your model number is listed.That's a heck of a deal.I'm going to have to bookmark that one.You'll have close to that price for a full rebuild kit with Float and jet.
If you get one take it apart and make sure that the Float is set correctly.
Edited by EricFromPa, April 29, 2015 - 08:20 PM.
  • bbuckler said thank you
#5 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 29, 2015 - 08:23 PM
Looks the same as an OEM briggs carb.Your model number is listed.That's a heck of a deal.I'm going to have to bookmark that one.You'll have close to that price for a full rebuild kit with Float and jet. only problem I see is the choke is on the opposite side but I can figure some way to hook up the cable
The only problem I see is the choke is on the opposite side but I'm sure I can still hook up the cable
Edited by bbuckler, April 29, 2015 - 08:24 PM.
#6 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 29, 2015 - 09:02 PM
I got the new jet out and the old installed back in.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 29, 2015 - 09:08 PM
Those are great carburetors.  I don't know where that guy gets them from, but his source is much better than mine.  My cost from my sources is more than that.
Ben W.
#8 EricFromPa OFFLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted April 29, 2015 - 10:25 PM
What was wrong with your old Jet?
#9 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 29, 2015 - 10:39 PM
nothing I just put the new one in cause it was in the carb kit.
#10 EricFromPa OFFLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted April 29, 2015 - 10:48 PM
Oh ok.Well I'm glad ya got the new one out.
Did ya get her running again?
SS15 is one of my favorite Sears GTs.Briggs engines are super easy to work on,good on fuel and have plenty of torque.
I'm going to try to swap my little Sears Custom 10E for a SS14 that needs some work as soon as I get the rest of the parts I need to put it back together.Found one locally that needs some lovin but is supposed to be a decent runner.Someone painted it GREEN lol that's gota be addressed ASAP.
#11 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 29, 2015 - 10:59 PM
It got dark before I could install it back. So far I like it better than the cub I had
#12 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted April 29, 2015 - 11:24 PM
i got a ss15 (well sub 15 with upgrades and repaint) but that old 16hp briggs i stuck on it is powerful.and i like this sub 14 i got last week too needs few bugs worked out on it and it will be doing some work this year.
#13 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 30, 2015 - 09:04 AM
It running once again but it doesn't act right I think maybe the pump is going bad.ImageUploadedByTapatalk1430402658.172940.jpg
#14 bbuckler ONLINE
bbuckler
  • 3,447 Thanks
  • 3,057 posts
Posted April 30, 2015 - 02:15 PM
Running rough just like it did before I got the carb kit and cleaned it.
