bush hog mower deck parts needed
28 replies to this topic
#16 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 24, 2015 - 09:35 PM
found the owners manual for the blade under the manual section. didn't know there was a manual section. that blade is the FB-48. will get the blade back off tomorrow and make the lift bars and the guide angle pieces for the front. I have  a set of springs that should work.  thanks. will post pics once I get it back on the right way.
  • olcowhand and KennyP have said thanks
#17 KennyP ONLINE
  • 38,377 Thanks
  • 45,933 posts
Posted May 25, 2015 - 05:48 AM
thanks you have helped a lot. this blade is not listed in my attachment pamphlet. I have looked all over the internet and cannot find any pics of this blade. I believe my D-47 (one in pics) is a 1968 or a 1969, I have two D-47s, this one is all origional down to the paint and letters and my other one is rough. also I have the message reply checked. only got a few emails before I quit getting them.
You may have to recheck the box. Sometimes when there is a software upgrade here, things get set back to a default and you  have to redo  those things.
  • olcowhand said thank you
#18 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 25, 2015 - 11:45 AM
got it mounted like it is supposed to be. made the 4" brackets and they were way to short. ended up having to make 8" brackets for everything to connect. the angle iron on the front is not the correct size but it works and the springs make a world of difference. it was impossible to raise the blade up by myself without the springs. now just need to knock the pivot bolt loose so I can move the blade side to side.
  • olcowhand and LPBolens have said thanks
#19 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 27, 2015 - 11:19 AM
looked up the Wisconsin engine serial number and the bush hog in the pics came back as january 1965. never did know the exact year it was produced. now my other bush hog the engine serial number plate is missing. can anyone tell me if the serial number is also stamped somewhere on the engine. thanks.
#20 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted May 27, 2015 - 11:20 AM
Wisconsins only had the ID numbers on that top shroud plate
#21 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 27, 2015 - 07:08 PM
ok. thanks. the shroud has been replaced on that tractor. the schroud is white and the rest of the motor is red.  the serial number for that schroud came back to january 1964. I was told from bush hog in a letter many years ago that the D-47s were made from 1966 -1972 so am wondering if these engines were sitting on a shelf or something when bush hog placed the engine orders.
#22 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 27, 2015 - 07:33 PM
From the price list I have, the D4-7 first shows up in the 1966 October 1st price list. It is also listed in the 1967 December 1st price list as well. By the November 15th 1968 price list it is no longer listed.
Looking at your lift arm set up, I don't believe you have an early model D4-7.
Sorry if I missed it, but do you have serial number for the tractor pictured above?
Check your PM , I am sending you s message there.
Edited by sacsr, May 27, 2015 - 07:38 PM.
#23 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 27, 2015 - 07:55 PM
yes I do. the serial number for the tractor pictured is: 7429 and the serial number for the engine is: 3958125
#24 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 27, 2015 - 08:03 PM
Sorry. Just saw where you posted your serial numbers. Since I believe 7000 was the starting point for the D4-7, the 7100 numbered tractor is an early one, and would have a S7-D Wisconsin like you later model. I suspect it has the different type of lift arm, not sure when they changed the lift arm rod from the right side to the left. I don't have the answer what exact year either of yours were made. Maybe someone else can offer more help there.
#25 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 27, 2015 - 08:31 PM
ok thanks. my other bush hog has a serial number of: 7110. it also has the lift arm on the right side.  the front rims are different on it though. the 7429 has the four nuts that hold the rims on and the 7110 doesn't have any nuts that hold the rims on. rusty rim is the 7429 bush hog. white rim is the 7110 bush hog
Edited by lspencer001, May 27, 2015 - 08:42 PM.
  • Texas Deere and Horse and sacsr have said thanks
#26 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted May 27, 2015 - 09:22 PM
Here is an early lift arm set up. This may be George's D4-7, this picture was taken in Dover several years ago. Notice the seat assembly is different as well.
Edited by sacsr, May 27, 2015 - 09:23 PM.
#27 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 28, 2015 - 06:39 AM
got to looking and my other D-47 (7110) has the older seat pan. will have to drag it out of storage and try and get it up and running also. its in rough shape. all complete but rough.
#28 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,500 posts
Posted May 28, 2015 - 10:53 AM
I would say that the white rims have been replaced or repainted as they should be yellow like the rear rims. Great looking D4-7.. :thumbs:
#29 lspencer001 OFFLINE
lspencer001
  • 12 Thanks
  • 23 posts
Posted May 29, 2015 - 06:14 AM
yeah they have been repainted. have the yellow paint just haven't gotten around to it yet.
