G16XT Drive Belt
5 replies to this topic
#1 chieffan OFFLINE
  • 16606 Thanks
  • 9090 posts
Posted April 29, 2015 - 04:47 PM
Can anyone tell me what the length and width of the tractor drive belt is suposed to be for my G16 XT? I have a parts book on the way but this belt is all I need to have this tractor up and running. Thanks in advance.
Edited by chieffan, April 29, 2015 - 07:23 PM.
  • blackjackjakexxix and Sawdust have said thanks
#2 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted April 29, 2015 - 09:00 PM
This is one of those oddball size belts that can be tough to replace.
Bolens part # should 1729716
Length is 46.6" width is 43/64" (HB), Thickness is 7/16". It's wider than a standard A series or 4L belt and a 5/8" or B series belt is too wide and too thick. You may try a 1/2 x 46" or 1/2 x 47", but in the end you may well be better off finding a NOS Bolens belt for it.
Edited by ClassicBolens, April 29, 2015 - 09:10 PM.
  • LPBolens, Bruce Dorsi, blackjackjakexxix and 4 others have said thanks
#3 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted April 29, 2015 - 10:26 PM
I show I have that belt in stock,factory part
  • WrenchinOnIt, Sawdust, ClassicBolens and 1 other said thanks
#4 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 30, 2015 - 07:19 AM
If we went with new , I would be sourcing a metric belt
  • WrenchinOnIt, Sawdust and chieffan have said thanks
#5 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted April 30, 2015 - 02:29 PM
Took a look,I do have it
  • WrenchinOnIt and Sawdust have said thanks
#6 chieffan OFFLINE
  • 16606 Thanks
  • 9090 posts
Posted May 02, 2015 - 07:04 AM
NAPA had a belt that crossed over to the Bolens number so put it on.  Pulleys are a little rough and the new stiff belt keeps the driven pulley turning all the time.  Can't shift gears with out turning the engine off and then starting it in gear.  Hopefully that will clear up after some use.  Will see how that works out when the new ignition switch gets here.  Throttle linkage hangs up at the slow speed.  Will have to take it off and clean it all up good.    Just a few minor fine tuning things that go with the territory.
  • Sawdust said thank you
