another Kohler question k301
14 replies to this topic
#1 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 28, 2015 - 09:09 PM
well I thought I had this fixed but it returns. I have a Kohler K301 spec 47642d, last fall this motor would act like it runs out of fuel when it gets hot, I switched out the fuel filter, fuel pump and even changed the carb off a "no problem" k301 in another tractor with a bad BGB. thing seemed fine all winter, no problems. I figured I had fixed the problem. took the snow plow off tonight put the mower on it made 3 laps around the yards, same thing as last fall
anyone ever run into this before?
#2 DennyIN ONLINE
DennyIN
  • 343 Thanks
  • 207 posts
Posted April 28, 2015 - 09:24 PM
I had a kohler powered mower that run great until it got warmed up and would act like it was starving for fuel, pop, and die. Let it cool off and it would run like a champ until it warmed up again. The wire going out of the points box was partially in two. Replaced the wire and it worked great, problem solved. I would have to look at it to tell you where that wire went. My rememberer isn't what it used to be.
#3 bbuckler ONLINE
bbuckler
  • 3,476 Thanks
  • 3,069 posts
Posted April 28, 2015 - 09:41 PM
What about the head gasket ? The service manual recommend replacing every 5 years.
  • superaben said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted April 28, 2015 - 10:18 PM
This sounds to be ignition related to me.  I would start there and then follow down the path of the head gasket idea.
Replace your condenser if you haven't already done that.
Ben W.
  • Trav1s said thank you
  • 14,814 Thanks
  • 15,501 posts
Posted April 29, 2015 - 05:11 AM
Ben W.
Or coil breaking down after getting hot..
  • Trav1s and superaben have said thanks
#6 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted April 29, 2015 - 06:06 AM
I'll second the coil. Happened to me a couple years ago with my 125 cub cadet with a k301 in it.
#7 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted April 29, 2015 - 12:02 PM
Sticking exhaust valve only when hot, My MF 14 did about the same thing as yours. Drove me crazy trying to figure it out. I put some transmission fluid in with the oil, that seemed to fix it.  Noel
#8 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted April 29, 2015 - 08:47 PM
Very true as well, Brian.
Ben W.
#9 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 29, 2015 - 09:49 PM
well tried the coil, switch coil with one off a good running tractor. same out come.
#10 bbuckler ONLINE
bbuckler
  • 3,476 Thanks
  • 3,069 posts
Posted April 29, 2015 - 10:56 PM
Did you switch the condenser too ?
#11 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted April 30, 2015 - 04:39 AM
yes I did, took both off the same tractor and switched them both. sorry just forgot to type it in last night.
#12 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted May 05, 2015 - 06:20 PM
What tractor are you working on?
I wonder if it is a tractor problem not an engine problem.
Ben W.
#13 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted May 05, 2015 - 08:30 PM
Allis Chalmers 712H. I am to the point of sidelining it and pulling the motor and slap a rebuild kit in it.
#14 dodge trucker ONLINE
dodge trucker
  • 2,452 Thanks
  • 3,132 posts
Posted May 05, 2015 - 08:56 PM
what is "BGB"?   and I don't think it needs a whole rebuild solely based on what info I see listed here, anyway
#15 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted May 06, 2015 - 04:30 AM
BGB = Bevel Gear Box
