correct plug for 12hp kohler k301s
6 replies to this topic
#1 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 28, 2015 - 02:59 PM
need to know the right plug for my 7112h . and could someone tell me the difference between magneto , battery and breaker-less ? I believe my simp has a coil and points . I dont believe it has a magneto
that means I would set my points at .035 ? correct ? thanks for putting up with me guys I am having a blast making these old tractors run again .( well maybe not poppin wheeleys because the clutch is sticky....)
#2 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,189 posts
Posted April 28, 2015 - 03:20 PM
I'm not sure but I think they should be set about  .020.
  • alec said thank you
#3 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 28, 2015 - 03:48 PM
the book is giving me a choice for this motor ..025 for magneto .035 for battery  (?) and .035 for breakerless
#4 Bolens 1000 ONLINE
  • 14,982 Thanks
  • 18,140 posts
Posted April 28, 2015 - 04:56 PM
Champion RH10C
  • superaben and alec have said thanks
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 28, 2015 - 10:09 PM
The magneto would have a coil under the flywheel.  There is one wire running from the key switch under the blower shroud to that coil that is grounded when the key is off and open when the key is on, and one wire running out to the points.
The battery setup would have an automotive style distributor coil hanging next to your carburetor, with one wire running from the ignition switch with power when the key is on, and one wire feeding your points.  This is the most common tractor setup.
The breakerless setup on a K301 would have been a chip that you insert into the breaker points cover after you throw away the points.  There is no points gap on this setup.
Champion RH10C
If it is magneto, I would drop the "R" for resistor and run straight H10C's.   I would probably do that on a battery ignition tractor, too.
I've just got a bone to pick with resistor plugs I guess.  :rolling:
Ben W.
  • Alc and alec have said thanks
#6 alec OFFLINE
alec
  • 382 Thanks
  • 412 posts
Posted April 28, 2015 - 10:23 PM
superben ... thank you for the informative response . that is exactly what I needed to know . mine has the coil and no wire running under the cover that I can see .
  • superaben said thank you
#7 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted April 29, 2015 - 05:16 AM
This is the engine info from the Kohler Master Service manual on all K Series engines. It's located in GTtalk's Engine Wiki,
http://gardentractor...kohler/k-301-r8
